Big Block Mystery
Old Dec 21, 2023 | 05:05 AM
Olds Canada's Avatar
Big Block Mystery
I have what appears to be a 455 Big Block, casting number 398021Fa with partial VIN on the block of 33m335268 which indicates it should be a 1973 but it has A heads. Does anyone have any ideas on this or is it as simple as someone has installed A heads on a newer engine.
Old Dec 21, 2023 | 08:21 AM
There’s your answer. It’s not unusual at all for J heads to be replaced with earlier heads that flow better.
Old Dec 21, 2023 | 10:15 AM
Thanks for the response, would you have any idea what this engine came out of based on the partial VIN?
Old Dec 21, 2023 | 01:24 PM
sysmg's Avatar
I don't think it really matters. Anything could have been changed or nothing could have been changed since the A heads show it's not original. If you are trying to make more HP then most important would be the Compression Ratio. If it matters, get a boroscope and look at the pistons through the sparkplug hole. If the block is really a 1973 and has original pistons then you have low compression. A 1973 block is just fine. It's what you put in it that matters.
Old Dec 21, 2023 | 04:28 PM
Sugar Bear's Avatar
3 Olds Division,
3 1973,
M Lansing,
335268 the last 6 of the VIN of the car that rolled off the line with that block.
I don't think you can devise any other information with any degree of certainty from that number.
Old Dec 21, 2023 | 05:40 PM
Thanks for the information, the engine came in a 1970 Cutlass parts car so it was obviously not original to the car.
Old Dec 22, 2023 | 02:01 AM
The engine most likely came out of an A-body car. Lansing assigned blocks of sequence numbers to each platform. Typically the A-body cars got sequence numbers between 100001 and 400000 in that year, but there have been documented exceptions.
Old Dec 22, 2023 | 11:09 AM
gs72's Avatar
72Cutlass S
What models were in the 600000 range.
Old Dec 22, 2023 | 12:12 PM
69CSHC's Avatar
Top of the line Oldsmobile.
The Toronado.
https://toronado.org/public/FAQs/GenII/vin.htm
Old Dec 23, 2023 | 10:51 AM
LOUCKES'6487's Avatar
Big port A heads
Moegs
Oct 15, 2022 08:36 PM
Phoenix8990
Oct 28, 2020 12:12 PM
Scott Krafft
Feb 10, 2016 01:31 PM
christine fury
Mar 27, 2009 09:50 PM
ZASX
Mar 11, 2008 10:44 AM
