BBO bolt ID
Old Jul 20, 2008 | 10:30 PM
geckonz08's Avatar
BBO bolt ID
am sure someone will b able to help here. 66 toro 425 block -two bolts in block either side of camshaft housing and behind timing cover .what is behind these please?
Similarly at rear of block and opp. rear cam housing --one frost plug? and a bolt which requires a hex key to undo --What are the purposes of these also tx
cheers
mike
Old Jul 21, 2008 | 07:05 AM
cheers
mike
Those are plugs in the ends of the main oil galleries. Very important. Also, be careful when you take them out, as a couple have very small holes to oil the distributor and timing chain and must be put back in the correct place.
Old Jul 21, 2008 | 12:09 PM
geckonz08's Avatar
Thumbs up
Again , thankyou Joe
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
