Bang for the Buck Purchase
Old Jun 7, 2018 | 11:30 AM
Wyocutlass71's Avatar
I have been looking around for a BBO for my 1971 Cutlass. I have found these two engines for sale locally.
One is a 425 that has been rebuilt. The seller is very descriptive of what he has done and seems to know his stuff.
https://www.ksl.com/classifieds/listing/52056953
The other is a 455 that came out of a boat. The guy builds boat motors professionally, and in theory, should know a 455 pretty well and know how to get power out of it.
https://www.ksl.com/classifieds/listing/51014224
For a daily driver that wants to be fun (without spending a ton of money) which would you choose? Thanks for the help!
Old Jun 7, 2018 | 11:38 AM
Unless you can get more detail on the boat motor, I'd go with the 425. Boat camshafts are probably not what you want to run on the street. Of course, the 425 only says "stock camshaft" - which one? There were several. I'd also plan on replacing that goofy Offy intake. You'll be a lot happier with a dual plane.
Old Jun 7, 2018 | 11:40 AM
Do you have a recommendation for a change of intakes? I also have a quadrajet carb that I just rebuilt, would that be a good match?
Old Jun 7, 2018 | 11:47 AM
Unless you plan to run an O.A.I. hood, I'd use a Performer. I'm a big Qjet fan.
Old Jun 7, 2018 | 11:52 AM
Thanks for the help! I am pretty new to this, and I want to stay with Olds as much as possible.
Old Jun 7, 2018 | 12:43 PM
I'd stay away from the boat engine, they are easily over rev'd which could lead to bearing failure.
Old Jun 7, 2018 | 12:46 PM
Does that come from the boat cam?
Old Jun 7, 2018 | 01:21 PM
No, it comes from a loose nut behind the throttle and possibly influenced by alcohol.
Old Jun 7, 2018 | 01:39 PM
Thanks oldcutlass! Like I said before, I am still really new. I am wanting to learn as much as possible and I hope I don't come across... well dumb haha.
Old Jun 7, 2018 | 01:55 PM
Nope, your doing great my friend.
Old Jun 7, 2018 | 03:26 PM
Years ago I had a QuadraJet that was a boat application. The metering rods were very unusual, with no taper. I figured this was due to jet boats essentially having two operational modes: idle and WOT.
wyocutlass
May 21, 2015 09:47 PM
Flye
Mar 23, 2013 10:58 AM
Bernhard
Nov 11, 2012 04:00 PM
defiant1
Oct 7, 2010 07:40 AM
DAN76
Apr 15, 2009 09:01 PM
