Back pressure
Old Nov 4, 2014 | 11:53 AM
sammieolds's Avatar
Question Back pressure
Hi All I need some advice on this engine its a 400 bored over 60 I always had blow by or back pressure since rebuilt I but Atomic EFI on it and notice I was getting a lite coating of oil on the throttle body,no pcv 1 valve cover goes to air cleaner ,other has a vented cap, Well I took of the one going to the air filter blocked it at air cleaner ,then I put one on with no vent hole. I didn't notice it before, But I took it for a ride and it blew the other valve cover breather off, so I changed breathers one in each valve cover and a oil vent cap, seams alright but I was thinking of adding a pcv to exhaust pipe or a catch can what do you guys think Thanks
Steve
Old Nov 4, 2014 | 04:21 PM
Do you have a PCV to manifold vacuum?
Old Nov 4, 2014 | 04:36 PM
sammieolds's Avatar
Yes but last time it was hooked up it sucked the oil out
Old Nov 4, 2014 | 06:03 PM
You need valve covers with baffles. Without a PCV hooked to vacuum you will blow oil out the fill tube and dipstick tube. I supplemented the PCV with hose running from the valve cover breather to the air cleaner for some extra vacuum on my old 330.
Old Nov 5, 2014 | 04:04 AM
sammieolds's Avatar
Eric, I have baffle in the valve covers,and I tried the air cleaner thing ,Not sure what to do
Steve
Old Nov 5, 2014 | 06:29 AM
Perhaps modifying your valve covers with different baffles or get a breather that will accept a PCV.
Use this to your aircleaner:
Something like this for your PCV
Old Nov 5, 2014 | 11:33 AM
sammieolds's Avatar
Eric ,I had that set up. To the air filter but it was leaving a oil film on my new EFI system I don't want gum it up?
Steve
I have roller rockers on this so I have tall covers w/baffle in them
Old Nov 5, 2014 | 01:11 PM
With excessive blow-by that is forcing crankcase gases and oil mist out wherever it can, this seems like one of the short list of options. It's probably smelly with so much blow-by, though. If you can connect a PCV in the system somewhere, that should draw the blow-by into the intake to be burned. The W engines had a PCV port on the intake manifold and a vent in each valve cover - that setup may be an option for you, but you may need a baffle inside the intake where the PCV port goes through.
Old Nov 7, 2014 | 02:12 AM
rustyroger's Avatar
'87 Delta 88 Royale
There seems to be an elephant in the room.
Maybe your rings aren't sealing properly, or one was broken when you installed the pistons.
Have you given it a compression test?. If the readings are low, or one cylinder is significantly lower than the others it may be news you don't want to hear.....
Roger.
<Roy>
Feb 26, 2013 05:03 PM
foreverolds
Dec 1, 2012 07:07 PM
Run26.2
Aug 10, 2006 07:40 AM
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
strtolds
Oct 22, 2002 09:17 AM
