1967 442 aluminium radiator fitment
Old Oct 31, 2014 | 07:50 AM
Pewter442's Avatar
Hey guys so my father in law bought a 4 row champion radiator for the 442 and it requires new mounts to be made. Has any one already tackled this adventure. I'm in need of some ideas on how to build new mounts. I have a couple ideas but thought I would ask.
The new radiator has no provisions for any mounts so all will have to be fabricated. I don't have a welder that can do aluminium so I won't be able to add any mounts to the radiator it self.
Thanks for looking
Old Oct 31, 2014 | 07:57 AM
Oldsmaniac's Avatar
They sell factory style iron mounts that are wider for 4 row radiators and the rubber cushion inserts. These can be welded where you need them or even screwed down. It is crazy that a new radiator does not have formed areas for mounts of some kind either top and bottom or on the sides.
Old Oct 31, 2014 | 08:04 AM
Pewter442's Avatar
Yeah its a big race type radiator. It get pretty hot here in the summers and he doesn't want any cooling issues. The bottom of the radiator is pretty square and flat
Old Oct 31, 2014 | 08:16 AM
Oldsmaniac's Avatar
So what I would think would be factory style U brackets, possibly build a frame for it, straps, or something like that.
Old Oct 31, 2014 | 09:30 AM
Pewter442's Avatar
that's an idea. what I thought of doing was getting some angle iron and building a pocket for the bottom and top and putting some rubber in it to cushion it
Old Oct 31, 2014 | 05:02 PM
Pewter442's Avatar
This is where it will sit. Mind you the top and bottom need to be powder coated still.
Old Oct 31, 2014 | 05:05 PM
Pewter442's Avatar
Pewter442's Avatar
Old Oct 31, 2014 | 05:08 PM
Pewter442's Avatar
Here is what I came up with for the bottom. Still needs to be finish welded.
Old Oct 31, 2014 | 05:09 PM
Pewter442's Avatar
Old Oct 31, 2014 | 05:14 PM
Oldsmaniac's Avatar
Looks like your getting it, just come up with something to keep the top from tilting forward and back....
Old Oct 31, 2014 | 06:20 PM
Pewter442's Avatar
Yeah I have the metal cut out already for the top I just need to weld it on I ran out of time today so I will weld it up tomorrow.
Old Nov 1, 2014 | 09:16 PM
hilbily's Avatar
I mount this same radiator in stock cars all day long. Your on the right track. I take the 1"x1/8" flat bar and just fab up saddles the go underneath each end just in from the tanks. Probably use the stock style bracket to hold the top. Your way looks fine.
Old Nov 2, 2014 | 07:27 AM
therobski's Avatar
For all the guys reading this thread just another idea, I bought a later model Suburban Radiator from Auto Zone for around $150.00 and two hose reducer sleves from NAPA and it drops right in. No welding, cutting, carving. It keeps my 67 with a strong 455 at 160 degrees, rarely sees more than 180 degress in Dallas heat. In my 64 F-85 pro-touring build under construction I bought a Champion radiator and with the wider Olds mounts it dropped in but I had to modify the top hold down bracket due to the thickness of the radiator. That is some nice work getting it to fit with quality!
Old Nov 2, 2014 | 07:47 AM
Pewter442's Avatar
Hey thanks. For the top in using 1/2" angle. Should have it done here in a couple hours.
Old Nov 2, 2014 | 10:47 AM
Pewter442's Avatar
And its done! Works perfect.
Old Nov 2, 2014 | 10:48 AM
Pewter442's Avatar
Old Nov 2, 2014 | 10:50 AM
Pewter442's Avatar
Old Nov 2, 2014 | 11:27 AM
therobski's Avatar
Those welds are really nice, great job. Are you going to use some sort of a cushion-rubber to sit the radiator on?
Old Nov 2, 2014 | 02:43 PM
Pewter442's Avatar
Thanks man. Yeah I plan to use some adhesive backed rubber weather stripping I found at the hardware store.
Old Nov 4, 2014 | 09:39 AM
Pewter442's Avatar
Just sent the pieces off to be powder coated to match everything else. Should have the pieces back on Friday and have it all put back together.
Old Nov 7, 2014 | 02:31 PM
Pewter442's Avatar
IMG_20141107_141818_zpsr7nn1tir.jpgJust got the pieces back and put them in.
Old Nov 7, 2014 | 02:33 PM
Pewter442's Avatar
Old Nov 7, 2014 | 02:34 PM
Pewter442's Avatar
Old Nov 7, 2014 | 04:52 PM
lemoldsnut's Avatar
Nice job. I highly recommend you also use the factory style rubber that goes on each side of the radiator it helps keed the air flow thru the radiator instead of around it.
Old Nov 7, 2014 | 06:54 PM
Pewter442's Avatar
We have them I just need the pieces that attach them.
Old Nov 8, 2014 | 06:29 AM
therobski's Avatar
Those are those dark green in color pieces that are square on one end and some sort of tension loaded pointed on the other. I think I got mine from Fusick or Ames performance. If you were my neighbor I give you some
Old Nov 8, 2014 | 08:56 AM
Pewter442's Avatar
Haha yeah that would be nice. Those clips are not high on my lost right now. Being a frame off I have lots of other things to do. Getting close to being able to fire her off though.
SkylinesSuck
Aug 4, 2014 05:59 PM
Mike77
Tech Editor's Desk
Jun 10, 2012 09:28 PM
D Appeldorn
Jun 4, 2012 10:18 AM
evans_78
Mar 2, 2012 11:18 AM
CLcutlass
Jul 28, 2011 07:51 PM
