B heads on later engines
Old Aug 23, 2008 | 05:57 PM
2blu442's Avatar
Hey all
I'm dismantling a couple 1966 Toronados and am looking at the B heads. I know I've read that there's 39 degree and 45 degree angles in the cam/lifters of the 425's but have never really paid attention to it. Can someone tell me if the heads between the two can be interchanged? Do they need some modifications to allow the pushrods to go through the hole in the heads to the rocker arms at the correct angle on the newer engines? John
Old Aug 23, 2008 | 06:20 PM
Originally Posted by 2blu442
Hey all
All you need to do is open up the pushrod holes to accommodate the different lifter angle. In many cases Olds used the same castings for both lifter bank angles.
Old Aug 23, 2008 | 06:23 PM
Oldsmaniac's Avatar
You should be fine using B Toro heads on 39 degree big block engines as the Toro was a 39 degree engine. You run into trouble when you use 39 degree heads on a 45 degree block. I am not sure if 5/16 pushrods will clear without opening the holes where pushrods go thru in the heads. I am sure that 3/8 pushrods wont clear.....been there with G heads on a 45 degree 1966 425.
Old Aug 23, 2008 | 06:48 PM
2blu442's Avatar
B heads
Thanks for the help guys! John
mashbaugh
Sep 17, 2012 08:40 AM
yeahbuddy
Jun 29, 2010 09:48 AM
Joe From NY
Apr 14, 2010 07:41 PM
Ranzan
Nov 27, 2009 07:45 AM
Aussie67Delta88Custom
Dec 31, 2007 05:35 AM
