ARP Bolts Confusion
ARP Bolts Confusion
Looking for more stuff for my build and while looking up ARP's listings, they have stuff for the 350-425 and stuff for 455 specific. Can someone clarify this and tell me what I need for my 400? I thought 400-455 was the same?
You are correct. All BBOs use the same bolts, some of which are different for SBOs. As usual, the catalog is incorrect. Just get 455 parts for your 400 and ignore what the catalog says.
early 400, 65 to 67 use the same rod bolts as the 330, 350, 425.
Rod bolts for the 455 are the same as the late 400, 68/69
You always re-size the big of the rod when changing the bolts
You hone the big end of the rod, align bore is for the mains, then you align hone to spec.
Gene
Gene
I did not know that the early BBOs used the SBO rod bolts. I would have thought that the 3" journals required longer rod bolts for all BBOs (and diesels).
Dang, I just got the bolts here, time to exchange them. Just to clarify, the rods use the 350-425 bolts (#184-6021) and the mains use the 455 bolts (#185-5001)? Those were the only 2 that I wasn't sure about.
Thanks Jensenracing but I ordered them before I asked and I now have them all here, lol. I'm guessing the rod bolts will need to be exchanged since I got the 455 ones and I'm seeing I need the 350-425 ones, I'm building a '66 400 and I thought all big block stuff is the same.
RAMBOW
May 27, 2017 06:11 AM
