Any help figuring HP & torque? Thank you
I have a 455 .060 over...468 I think it comes out to. Icon premium forged flat top pistons. Eagle H beam rods. Comp Cam XE274H Camshaft, Hydraulic Flat Tappet, Advertised Duration 274/286, Lift .520/.523. E heads mildly ported new valve job done. Edlebrock performer intake. Holley 830 HP. Compression is at 9.75. I also added a MSD pro billet distributor and 6al box. Hooker super comp headers 1.75" primaries and 3" collectors running a full 3" flowmaster exhaust all the way. Just did the break in and wondering what I can expect out of this combo. Thank you for every ones help its greatly appreciated. Let me know if I am forgetting anything to help out.
What stroke on crank are you using? Stock 4.25 or offset 2.20 chevy ect,ect.I can tell you this much you are over 400 hp.but below 475. If i had a pipe max program i could run it threw and see what it spit out but i don't.
I had a similar engine dyno last year but 10.25:1 compression, Torker and slightly more cam. It made 485 hp and 522 TQ with an 850 AED carb on the engine dyno. Yours' will make a little less hp. My guess is you are making 1 hp per CID at 468 hp and 520 TQ.
I think you are close Dave could be slightly lower. I know of one that has Torker also with the same cam basically but a 825 carb. This engine hasn't been on a dyno but runs 1150's/11.60's with E iron heads gasket clean up only.Less ci 461.
starr88
May 23rd, 2011 05:06 AM
