Another Carter 750
Old Mar 18, 2012 | 07:53 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Another Carter 750
Just bought a NOS Comp series front carb to go with the back one that I had bought new many years ago. Now I'll have a visible label Current set up attached. The new one is in the mail.
Old Mar 18, 2012 | 09:04 PM
Rickman48's Avatar
Dual Quads = instant bog, from my experience!
Wish you well on that setup!
Looks good!
Old Mar 19, 2012 | 06:14 AM
That looks awesome!!!
Old Mar 19, 2012 | 09:06 AM
cutlassefi's Avatar
Looks great but I have to ask, why didn't you go with 2 500's instead? You had to buy one carb anyway. It sure would run better.
Jmo.
Old Mar 19, 2012 | 01:57 PM
Navy P-3 FE (Ret.)
Thanks for the comments, haven't installed the new one yet.
I at some point may get the smaller carbs but at over $500 for both I'll wait, the one I got was $200. As far as running good, it does. I've messed with them enough and finally got them tuned where I don't bog at all. Since I've got progressive linkage, the back carb I got set for most of the idle and the front adjusted so the throttle plates are open just a little. Seems to be a smooth transition when the second carb comes into play. I had put smaller jets in them that may have made a difference. Do wish I got better mileage with the good gas at $8.54 a gallon and 93 over $4.00 Course it's not about the mileage.
Old Mar 23, 2012 | 07:04 AM
Navy P-3 FE (Ret.)
Well it seems I certainly can't make up my mind. I have two Edelbrock Thunder series 500's coming today. I replaced the new Carter I haven't got yet. I'll just hold on to it along with the other two carbs. Maybe I won't have to tune them as often. Got a 4" Harwood Cowl Hood scoop on the way also.
Old Mar 23, 2012 | 07:32 AM
Did you order just the scoop (bolt or bond on?), or the hood with the scoop on it? I was thinking of the short bolt on euro scoop and going back with my hi rise intake.
Old Mar 23, 2012 | 09:07 AM
Navy P-3 FE (Ret.)
I'm getting the bond on scoop only. Putting it a VFN louvered hood. I was thinking bolt on but wanted to save a little money.
http://www.summitracing.com/parts/HRD-1107/
Old Mar 23, 2012 | 09:54 AM
Please send or post some pics when you get it done if you don't mind.
Old Mar 23, 2012 | 10:04 AM
I was thinking of this one for mine.
http://www.summitracing.com/parts/HRD-4166/
Old Mar 23, 2012 | 07:29 PM
Navy P-3 FE (Ret.)
I'll post pics, I like the one you may get better than my choice. I was looking at something wider because the way my fuel lines ran. Well now that I changed my carbs the fuel lines are not an issue.
Carbs are on, need to get a PCV hose and an AN fitting to finish the fuel feed line. Just attached some extra elbows I had so I could fire it up. I had to replace the header gaskets again and wanted to warm it up so I could re-torque the header bolts.
Old Mar 25, 2012 | 12:33 PM
Navy P-3 FE (Ret.)
Got the scoop but I think I need one a little longer. They have one about 3 inches longer. Should it be longer? Carbs are installed.
Old Mar 26, 2012 | 02:40 PM
Navy P-3 FE (Ret.)
Got the new carb even though I won't used it, it's not often you find a NOS version still in original box. The other carb only has maybe 25 hrs on it.
Old Apr 2, 2012 | 07:06 PM
Navy P-3 FE (Ret.)
It's not done but I got a different scoop. Will start working on it soon.
67Olds442X2
Aug 27, 2014 05:25 PM
67Olds442X2
Feb 11, 2012 01:05 PM
59-59-59
Jun 3, 2010 08:43 PM
Oldsmobomb
Aug 2, 2009 08:02 PM
Oldsproject
May 10, 2007 06:03 PM
