All Stock/Original '71 455 up f/ grabs
Got a '71 455 and am considering getting rid of it, as I'm into another Olds project right now. I know you guys always relay info when blocks/engines are available to one another, so I wanted to do the same.
my edit: Forgot to add that the TH400 turbo transmission comes w/ the engine f/ the $300.00, original trans that came w/ the engine.
the engine ran good when I had it in the car, cylinders are clean and letters on the pistons from the factory, has new fuel pump and water pump.
the TH400 turbo transmission goes along w/ it f/ the $300.00. Sorry, forgot to include it in the first post. The original one that came w/ the engine in the car.
the engine has clean cylinders, pistons have the letters on them from the factory and it ran good before I took it out of the car.
Just contact me whenever you can. Next month is fine. I'll be here. Thanks. I'll send you my phone number.
Her mouth says no, but.... if she didn't pull a huge fit, then she's not totally against it! She's supposed to act that way, she doesn't want to make you feel that you can get anything you want, when you want it. She knows that with marriage, what hers is hers, and whats yours is also hers!
