8x2 intake
Old Dec 24, 2014 | 02:44 PM
Octania's Avatar
8x2 intake
on ePay at this time
http://www.ebay.com/itm/Offenhauser-...16.m2518.l4276
"This is a N.O.S. (new old stock) Offenhauser tunnel ram base with a kuctom cast / fabricated 8 deuce top. It will need a good cleaning before you use it. The top is cast in 2 pieces & welded together with the outside weld ground down & blended in & the inside seam epoxied sealed. The casting is a little on the crude side giving it a older look. It uses 3 bolt 2 bbl. Stromberg 97 or Ford 94 carbs."
Quite a sight
Old Dec 24, 2014 | 03:29 PM
That would be a cool and unique setup. Not sure how efficient it is.
Old Dec 24, 2014 | 07:50 PM
But why? WHY????
Old Dec 24, 2014 | 08:58 PM
young olds's Avatar
that actually looks kinda cool but im a sucker for multi carb setups, lower like a man-a-fre intake would be cooler though
Old Dec 24, 2014 | 10:22 PM
z11375ss's Avatar
Senior Moment Member
I don't think that would fit under my hood.
Old Dec 24, 2014 | 10:41 PM
young olds's Avatar
why would you want it to!!!!
Old Dec 25, 2014 | 08:15 AM
Not very.
Even a single 4bbl would make more power.
Old Dec 25, 2014 | 08:24 AM
Probably be one step above driving a Hilborn injection setup on the street.
Old Dec 25, 2014 | 08:38 AM
pogo69's Avatar
morgan
might as well well stick a couple Danish Windmills under there also
Old Dec 25, 2014 | 11:43 AM
cutlassefi's Avatar
Not very.
X2.
The first problem I see with it is way too much plenum for a street application. Between the top piece and the existing top of the tunnel ram that's a lot of area. It'll be that much easier for the fuel to drop out of suspension.
Old Dec 25, 2014 | 05:43 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It would be fun putting the linkage together. There is a reason these are rare. Nobody wanted them.
Old Dec 27, 2014 | 07:52 PM
Octania's Avatar
I think this item is for when appearance and needless complication are more important than drivability and performance.
Maybe it can be used as an air inlet, with injectors hidden down in there for an FI system. There's room enough in there for quite a bit of voodoo.
Old Dec 28, 2014 | 06:55 AM
bisscrac's Avatar
I was thinking the same thing.. linkage nighmare.. Plus tuning the carbs all together would be a p.i.t.a.
BUT it would be super bad *** looking set up in a 30's model anything with open bay open headers....
Old Dec 28, 2014 | 07:03 AM
bisscrac's Avatar
this is a 27 but you get the idea
Old Dec 28, 2014 | 08:58 AM
Linkage fab really isn't that difficult. If you want all the carbs to open at the same time, it's pretty easy, actually. Progressive linkage is only slightly more difficult. If you can understand lever arms and simple geometry, you can build the linkage. Syncing the carbs is a different problem. You can buy TBI systems that look like Stromberg carbs with the injectors hidden in the fuel bowls. It wouldn't be cheap, but that's probably the only way to get this manifold to run decently.
Old Dec 28, 2014 | 01:48 PM
Boldsmobile's Avatar
Joe, if I added this to my collection would I finally have one that you don't?
Old Dec 28, 2014 | 02:11 PM
Yessir! You NEED that, Pete.
Old Dec 29, 2014 | 07:53 AM
Need or want?
Old Dec 29, 2014 | 08:07 AM
Need or want?
Don't try and talk yourself out of it. You NEED this intake...
Wildcard
Dec 26, 2012 07:48 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
71cuttyS
Oct 31, 2007 04:58 PM
