'71 W30 build and dyno session.
Just finished a W30 build, Jim and Robert yours are next, sorry for the delay!!
Build specs;
.060 over 455, Icon pistons
N crank
Eagle rods
H heads, stock 2.07/1.62 valves, no port work
W30 intake, stock
Matching Qjet, 1 jet change, could've used a couple more
W/Z manifolds
9.6:1
Custom Lunati Hyd roller, 229/234@.050, .542/528 lift
33* timing
414hp/546tq. Dyno sheets to follow.
Thanks!
Build specs;
N crank
Eagle rods
W30 intake, stock
W/Z manifolds
9.6:1
33* timing
Thanks!
Thank you. Most of that is in the right cam and overall combination.
But wait till you see the full dyno sheet. It was way fat throughout most of the pull. There was probably 15 more in it. However we ran out of time and metering rods.
Absolutely cannot wait to see mine posted here.
