71 Cutlass
The 68-76 accessory brackets are the same for big and small block. Toro used slightly different brackets. The thing to watch out for is the water pump and pulleys. The A/C pump is longer than the non-A/C pump and the pulleys go with it. Just be sure to use a matching set of brackets/pump/pulleys and you'll be fine.
