71 Cutlass
Old Oct 28, 2007 | 12:07 AM
canucklehead's Avatar
71 Cutlass
I am in the process of swaping my 350 for a 425.Can I use the same pullys and brackets on the front of the motor for alt,p steering?
Does anyone have the brackets for sale?
Old Oct 28, 2007 | 06:40 AM
2blu442's Avatar
Yes, I believe they will interchange. I may have the brackets and pullys, is it an AC car or not? Are you going to use the 1971 Power Steering pump and AC compressor? John
Old Oct 29, 2007 | 08:45 AM
The 68-76 accessory brackets are the same for big and small block. Toro used slightly different brackets. The thing to watch out for is the water pump and pulleys. The A/C pump is longer than the non-A/C pump and the pulleys go with it. Just be sure to use a matching set of brackets/pump/pulleys and you'll be fine.
