'70 vs. '74 455 differences
Old Dec 28, 2013 | 05:33 AM
TEB's Avatar
TEB
Looking for some general information on these engines. Several years ago, I bought a 455 out of a '70 98 at a bone yard. They guaranteed that it would be rebuildable, but it turned out to have a broken rod and significant block damage. To compensate they gave me a 455 out if a '74 FS wagon. My plan had always been to rebuild it and drop it into my C/S. I disposed of all the damaged parts from the '70 engine, but have the heads, intake, 7 pistons/rods, Q-jet, etc; and have the complete '74 engine.
Can I make a decent engine out of this stuff? What are the differences between the '70 and '74 block?
Recommendations?
Old Dec 28, 2013 | 06:24 AM
Short block differences 1970 vs 1973:
CR - 10.25:1 vs 8.5:1
HP - 365 SAE Gross vs 230 SAE Net
Heads
Pistons
Cam
Other differences:
Intake manifolds
Exhaust manifolds
Distributor (points vs HEI, different advance curves as well)
Carburetor
Emission controls
Accessory brackets
Air cleaner
It sounds like you've got the parts needed to supply a rebuild, but still need to do the machine work and replace the pistons, rings, bearings, etc.
Old Dec 28, 2013 | 07:14 AM
Originally Posted by joesw31
You should have no problems making it work. The most significant difference is the 74 block does not have the pedestal to attach 4 speed clutch linkage.
Actually, that depends. Most 1974 455s used FA blocks that did not have the provision for the equalizer as noted above, but there are documented uses of F blocks with the provision at least as late as the 1974 model year, as demonstrated by the VIN derivative.
Old Dec 28, 2013 | 08:32 AM
TEB's Avatar
TEB
It'll need the lower end done for sure, and some work on the heads. Is it just automatic to put all new pistons/rods, or could I find a good 8th piston/rod and re-use the ones I have?
Old Dec 28, 2013 | 08:56 AM
Lars's Avatar
Use the 74 block buy some kb132's. 0 deck it. 74 rods resized with arp studs. 70 crank E heads with big valves. Performer intake. 224ish cam
Old Dec 28, 2013 | 08:59 AM
oldstata's Avatar
Justin
I would tear down the 74 block have it checked before buying any pistons if the block needs boring the stocks wouldn't work if just a hone is in order sure you could find so e 70 pistons but your there why not upgrade to a lighter one Just my opinion
CaliBoricua
Sep 16, 2012 03:32 PM
red&blue442
Jan 14, 2011 03:00 PM
Lady72nRob71
Dec 14, 2008 04:51 PM
musicars
Aug 19, 2008 11:02 AM
texasred
Jul 31, 2007 11:33 AM
