70-72 455 Engine pricing
Old Nov 13, 2019 | 10:11 AM
JimHutch's Avatar
JimIAMN
What is the best source for determining engine pricing?
This engine has 5,243 miles since a rebuild in 2016.
Engine specs:
'70-72 Olds block no: 39602 'F', 455 cu.in, bored .030,
'66 'B' heads shaved .075, ported intakes, relieved exhaust, removed O2 bosses,
Stroked Crankshaft, 508 cu.in., Compression: 11.9,
standard cam,
Offenhauser Tunnel Ram Intake with dual Edelbrock 600 cfm carbs w/ elec choke, stamped 1406 0940,
Mondello 8 qt oil pan, Offenhauser Valve Covers,
Mallory Unilite distributer, and Mallory Promaster Coil p/n 29440,
New spark plug wires May 2017,
Headers,
New in April 2019: 80 gph mechanical Fuel Pump, 180 degree Thermostat, Power Steering Pump, Crankshaft Damper and seal,
May 2019 rebuilt A/C compressor,
Old Nov 13, 2019 | 10:43 AM
jensenracing77's Avatar
Is it in a car that they can hear run and drive before they buy it? If not, most people will not pay more than core price. For yous, maybe core price plus a little extra for the aftermarket external parts. I would guess around $1000. If it is in a car and they can drive the engine first then it would go up
Old Nov 13, 2019 | 11:32 AM
wr1970's Avatar
I know what it would be if i was buying a pig in a poke. Parts plus engine $1600 max.jmo
Old Nov 13, 2019 | 11:39 AM
cutlassefi's Avatar
I would want more information regarding how much they say it was stroked, and the rod and piston that’s in it.
Old Nov 13, 2019 | 01:28 PM
What, exactly, is a "standard cam"? That's only slightly less descriptive than "3/4 race cam".
Old Nov 13, 2019 | 07:16 PM
JimHutch's Avatar
JimIAMN
Thanks for the reply. The engine is still in the car, but has been totaled, so they won't be able to drive it. I'm working toward getting it started, but since the accident there is an electrical problem, so it's a maybe.
Old Nov 13, 2019 | 07:23 PM
coppercutlass's Avatar
Chevy budget Olds powered
Where was the car hit ??? Unless there is some way to run vitals on the engine like an engine run stand and do all the checks like leak down test compression test etc etc etc. sell it in parts and you will probably get the most that way.
Old Nov 13, 2019 | 07:30 PM
To get it to run just run power to the coil+ terminal from the battery, switched power or a temporary jumper to the solenoid to crank it, and have a gravity feed fuel supply to the carb. Once running to turn it off just disconnect the jumper wire to the coil+ terminal.
Old Nov 14, 2019 | 06:20 AM
JimHutch's Avatar
JimIAMN
The car slid sideways into a steep ditch and rolled onto the top. It shouldn't have affected the engine, other than oil draining into the cylinders while upside down, so I've removed the plugs to make sure any oil can get out, but there's no power to crank it over. The battery is fully charged, so I'm thinking there must be a short, or bad fuse.
Old Nov 14, 2019 | 09:06 AM
VinMichael's Avatar
Go on Craigslist to find comparable listings in your area. Get the engine running, preferably allow the buyer to drive it. That way the proof is in the pudding, and should get the best price for it that way.
Old Nov 14, 2019 | 10:13 AM
JimHutch's Avatar
JimIAMN
Thank you
Old Nov 14, 2019 | 10:14 AM
JimHutch's Avatar
JimIAMN
Thanks for the help.
Muggard
Jun 15, 2019 01:09 PM
folek
Nov 24, 2018 12:57 PM
CJG
Jul 17, 2016 03:52 PM
sbFALL63
Aug 28, 2013 12:44 PM
ldc7675
Jun 17, 2012 06:12 PM
