70 455 motor
Old January 28th, 2019, 06:33 PM
70-455's Avatar
70 455 motor
I have a rebuilt 70-455 motor..030 over with E heads.The machist took .100 tousandths out of the 10.5 to 1 pistons.The deck and heads have a clean up cut on them.Would anyone know what the compression would be roughly after the machining?
70-455 is offline
Old January 29th, 2019, 12:01 AM
brownbomber77's Avatar
I'm confused.....where did the machinist take .100" out of the pistons?
brownbomber77 is offline
Old January 29th, 2019, 01:39 AM
70-455's Avatar
Off the face.
70-455 is offline
Old January 29th, 2019, 01:50 AM
shiftbyear's Avatar
A few things you'll have to obtain to make a good calculation: Piston to deck height at TDC, Combustion chamber volume, head gasket thickness (crushed), any valve recess or dome in the piston, Although the factory advertised 10.5:1, that was blueprinted specs with a steel shim gasket. Good luck with your engine build.
shiftbyear is offline
Old February 8th, 2019, 12:05 AM
So the pistons are now .135" in the hole instead of .035" stock? What brand pistons are being used? I'm assuming with the information given, it's now a flat top piston?
4.155 bore
4.250 stroke
flat top pistons (now)
77cc combustion chamber
.038 compressed gasket thickness
.135 deck clearance
9.18:1 but 8.9:1 with 80cc combustion chamber which is probably more realistic
Old February 8th, 2019, 01:19 AM
70-455's Avatar
G.m.
Speed pro pistons.
70-455 is offline
redbaron442455
September 30th, 2018 10:58 AM
djdaveofkc
March 4th, 2017 10:38 AM
cdrod
July 8th, 2015 05:35 PM
sbceater
February 1st, 2015 07:28 AM
joepenoso
October 27th, 2011 07:34 PM
Quick Reply: 70 455 motor
