69 455 exhaust manifold and freeze plugs
Old January 10th, 2018, 07:09 PM
1965Jetstar's Avatar
Are you guys able to maneuver the drivers exhaust manifold out of the car without unbolting the motor mounts or top a-arm? I would love to remove the a-arms and do the bushings are ball joints but I've never done ball joints before and am scared anytime I see shims.
Also the block kept pushing out freeze plugs a couple winters while it sat. I replaced with the rubber expandable ones until I finally got a new radiator and fresh coolant installed. Is it pertant to install the regular freeze plugs or do the rubber ones work as fine? Does the block have to be lifted to access freeze plugs proper? It looked like there was one behind a motor mount if I recall correctly.
1965Jetstar is offline
Old January 11th, 2018, 07:13 AM
I have had to jack up the motor on my 67 Delta (same chassis) to get the manifolds in and out.
The shims are irrelevant. Once you replace the bushings and ball joints, you will need to have the car completely aligned anyway. The only certainty is that those current shims won't be right once the suspension is put back together.
Having recently done this on my 67 Delta, I was able to get everything in Moog from RockAuto except the non-existent upper ball joints. Kanter sells Chinesium replacements (at great personal expense), but I don't trust those. I got new old stock replacements from Craig at Mobileparts on this site.
joe_padavano is offline
Old January 11th, 2018, 08:03 AM
thanks. Pretty lame though. No wonder so many drove around with manifold leaks when I was a kid. And WTF with the dipstick placement? Probably just coincidence but that was the main spot blown out.
Old January 11th, 2018, 08:06 AM
??? "Lame"?
Remove one bolt through the mount and use a floor jack. Takes about five minutes.
Old January 11th, 2018, 09:01 AM
??? "Lame"?
the design being lame. Sorry. Probably 1 generation younger lingo. . I could get the manifolds out of my 69 Buick 455 without having to move the block. So yeah. I consider that design lousy. Or LAME as the cool kids would say.
Old January 11th, 2018, 09:03 AM
Awe. I didn't see your explanation. Sounds easy enough. Thanks. I thought you just wrote lame with question marks. Didn't see the 5min adjustment.
Old January 11th, 2018, 09:28 AM
Pulling the manifolds isn't exactly a routine maintenance process that you have to do every 5,000 miles.
Old January 11th, 2018, 09:55 AM
No cussing please.
Olds64 is offline
Old January 11th, 2018, 09:58 AM
Originally Posted by Olds64
No cussing please.
I've found cussing to be quite useful when parts don't fit the first time...
Old January 11th, 2018, 09:59 AM
That does work from time to time.
Olds64 is offline
Old January 11th, 2018, 11:35 AM
m371961's Avatar
I learned how to cuss when starting as a mechanics helper!
m371961 is offline
Caveman-455
May 7th, 2012 05:49 PM
Rich
September 4th, 2010 05:14 PM
Joeypete
October 16th, 2009 10:43 AM
gthmcty1
July 12th, 2009 08:39 AM
wagonman
March 7th, 2008 06:49 AM
Quick Reply: 69 455 exhaust manifold and freeze plugs
