69 442 - 400G full rebuild
Old Aug 12, 2023 | 11:38 AM
arruv89's Avatar
Hello olds fam,
Been a while since I've posted but I'm still working to get her on the road. Recently found out that the engine has bad main bearings and was recommended I do a full rebuild. The shop originally quoted me for around 9k. I unfortunately don't have that $$$ so I decided to take on the task of rebuilding myself with a mechanic homie who has more knowledge, experience and tools than me. BUT I wanted to get some input from the real experts on how I should tackle this rebuild. I think my goal is to get her as close to stock as possible. Maybe a different cam or aluminum intake. But nothing crazy for sure. I've been reading a lot of different threads on past 400G rebuilds and taking notes.
AGAIN open to all recs on what I should do? Will post updated pics soon.
Thanks again for all the help!
Old Aug 12, 2023 | 12:22 PM
rocketraider's Avatar
Oldsdruid
I'll be honest. With a G block, unless you're going for a numbers restoration, I'd find a 455 and rebuild that. Costs will be similar, easier to source internal parts and not as prone to grenading itself.
If you stick with the 400, hopefully those bad bearings haven't damaged the crank too badly and you can get by with a polish or .010 cut.
Old Aug 22, 2023 | 11:37 PM
arruv89's Avatar
Old Aug 22, 2023 | 11:49 PM
arruv89's Avatar
I bought this car from a guy who said he had the engine rebuilt. There was a new timing chain and sprocket. BUT opening it up I found that EVERY SINGLE bearing was turned. There was even one bearing that was flattened and wider than the rest. I think on the 4th or 5th piston. And there was numbers etched on the prod cap and big end im guessing to coincide with the piston number but the way it was assembled was actually backwards from its numbering. The crankshaft was was not rotating easily. And it had a '010 010' etched on it already.
Forgot to take pics of bearings but will post.
Old Aug 23, 2023 | 11:35 AM
acavagnaro's Avatar
It's your car and you can go whichever route you want. If it were mine, I wouldn't even consider abandoning the 400G. Sounds like you're not going to be prioritizing horsepower numbers and want a close to original strong engine. If that's the case, you'll be more than happy with a properly built 400G. Too many guys take the easy road and drop in a 455. To me, that's little better than doing an LS swap. Everybody goes straight to the 455. Dare to be different.
OK, enough of my commentary. Rebuild components for the 400G are available. Aftermarket cranks, bearings, pistons, rods etc. are out there. I know because I built mine. Hell, a lot of the stuff is the same for the 455 anyway. Talk with somebody like cutlassefi to get quality advice on parts combinations.
Old Aug 23, 2023 | 04:23 PM
arruv89's Avatar
Yes that is 100% my plan. I have a numbers matching engine and trans and I just want it as close to original as possible.
just realized i have the wrong carb for it tho. But not sure if this will work the same.
So I will be on the hunt for the original carb 7029251 RJ if anyone has one they would like to sell me. Preferably in working condition. I bought this one off of a member here and had it rebuilt and it didn't seem to run too nice. But it could be cause the whole engine was ****.
But yes thanks for the reply. I've seen @cutlassefi pop up on every single thread related to rebuilding engines. I am def going to reach out him for some help real soon. Just took everything to the machine shop. They said it was salvageable.
Will post more updates as I go.
Old Aug 23, 2023 | 06:32 PM
Oldsdruid
Sounds like, as is all too typical, someone who knew nothing about Oldsmobile engines got their hands on it. Even if their knowledge was Ford engines I'm having trouble wrapping my head around how this individual buggered up the rod and bearing installation. What is so hard about left bank 1-3-5-7 and passenger bank 2-4-6-8?
How bad is the crank? As you may know it's 68-9 400 only if you want to stay original. If it's already been cut 10/10 the next step is 20/20 if polishing won't clear up the damage. You may find a good machine shop that can build up the bearing surfaces by spray welding them, then machine them to original diameter.
Old Aug 23, 2023 | 06:47 PM
Same crank as the 455 engines, right?
Old Aug 23, 2023 | 07:01 PM
Bernhard's Avatar
455 Cranks are inexpensive just buy a new crank have it ground 10/10. Find one with the large N or small CN 68 to 73?
400 G is notorious for spinning rod bearings so make sure you get the clearances right and go with an aftermarket rod if its in the budget.
If your car is a 4 speed you will need a four speed crank or drill the new crank for a pilot bearing.
When selecting an aftermarket rod make sure it fits through the small bore.
Old Aug 23, 2023 | 07:34 PM
Oldsdruid
I thought so too Kenneth. 74 chassis parts book shows different part #s though.
Always thought the big driver behind the G block 400 was commonality with the new 455 on the engine lines.
Unless the difference is the 400 cranks were all drilled for pilot bearing and 455 were not. Parts book says "less pilot bearing".
Old Mar 22, 2024 | 01:21 PM
arruv89's Avatar
Engine update:
-aluminum manifold
-roller rockers, rods, and cam
Old Mar 22, 2024 | 09:30 PM
Bernhard's Avatar
Nice progress!
Old Mar 23, 2024 | 10:29 AM
Nice, but last thing I heard you say was you wanted to keep it original ...?
Old Mar 23, 2024 | 01:17 PM
arruv89's Avatar
"Everyone has a plan until they get punched in the mouth"-Mike Thyson
That was the plan going in until I learned the original cam was busted beyond repair. At that point i was convinced by the guy helping me to go for a roller cam bc of efficiency and blah blah blah. Made sense to me and I feel like I'm still keeping all the original parts for potential later original rebuild and I'm still keeping the factory heads, carb, and exhaust manifold. He also convinced to upgrade the water pump since we discovered it was not the original 400269 but rather the set up off a 65-67 442 384783. To me it seems like a slight upgrade from bone stock but still has the original engine essence if that makes sense haha..still plan to keep interior and body all original.
Old Mar 23, 2024 | 04:20 PM
Originally Posted by arruv89
"Everyone has a plan until they get punched in the mouth"-Mike Tyson
Good one!
Sounds like you've considered every angle. Best of luck; I'll be watching.
Old Mar 23, 2024 | 05:36 PM
Bernhard's Avatar
You might want to consider headers as they don't detract in my opinion and are a very day two type modification.
Old Mar 23, 2024 | 06:52 PM
arruv89's Avatar
I def have been considering headers at some point. But I'm also getting very impatient and want to drive her asap. Also, it's my first muscle car and I really want to feel the upgrades after this..
Is there any headers you recommend??
Old Mar 23, 2024 | 07:42 PM
Bernhard's Avatar
Bernhard wrote:
We ran KB and hooker headers in the past both fit well and sealed well. I don't have any current experience with other brands that are on the market today. I do like the look of the ARH headers, they are not cheap. You should do a search as this question has been asked many times.
If you are looking to chip away I'm a fan of classic daytwo modifications.
1. Taller rear gear
2. Ignition MSD 6AL box or other brand.
3. Fuel pump that can keep up to performance modifications
Old Mar 24, 2024 | 04:57 AM
brotherGood's Avatar
1. Taller rear gear
Gear is a must. I'm realizing that with my 400G build-I kept the 3.23s and im regretting not bumping up to at least 3.55. Also, with headers.. isn't there a concern with the factory routing for power brake setup/lines/valve?
Old Mar 24, 2024 | 04:25 PM
Bernhard's Avatar
Bernhard wrote:
I never had problems with the KB or Hooker headers. Most aftermarket bolt performance upgrades are not OEM bolt on, but require some minor modification. I personally enjoy this part of the hobby as I'm aiming to make as clean a install as possible. I always appreciate seeing others clean install of aftermarket parts. Some go to great lengths to hide or make their performance up grades appear stock, this shows how creative the installer is.
Old May 12, 2024 | 01:19 PM
arruv89's Avatar
Quick update and question.
QUESTION: I installed the edelbrock aluminum intake manifold. But now I need to install a electric choke for the carb. Does anyone have a good recommendation for the electric divorced choke kit?
Old May 13, 2024 | 05:52 AM
allyolds68's Avatar
depending on your body build date a 29251 with a build date of the 79th day of 69 is the correct carb for an automatic 442. It's well documented that the "70" was left off on some carburetors.
Old May 13, 2024 | 04:55 PM
I would tend to disagree ... these engines are (in)famous for being low-end torquers that don't like to rev. 3.23 is probably optimum for keeping a G-block in its sweet spot. 3.55 might start to run into the law of diminishing returns unless you're going to address limited breathing and reliability over 5000 RPM, and at that point you might as well swap in an LS and be done with it.
That last part was a joke. Don't do that.
Old May 13, 2024 | 05:06 PM
Sugar Bear's Avatar
Most importantly...it is now the correct color
Old May 13, 2024 | 05:23 PM
Lol. To be fair, I've since realized part of my issue was transmission related. Haha. I do agree though, the higher (numerical) gear will drive the need for better flow the be more and more.
Old May 30, 2024 | 02:19 PM
arruv89's Avatar
Updates and cylinder 7 question
Engine is in and running.
Ran into some defective lifters that needed replacing. A couple leaks that were addressed.
But now there seems to be something going on with cylinder7. The compressions for all are around 140psi. When I cover the carb the rpm does not go up but cylinder 7 is running at about 100 degrees colder than the rest. Anybody have any ideas as to why????
Thanks in advanced for all the help!
File Type: mov
Old May 31, 2024 | 06:39 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Basic questions:
Does #7 have 140 psi?
Have spark at #7?
Whats the plug look like?
Swap a plug and wire from another cylinder.
Report back.
Old May 31, 2024 | 06:48 PM
Sugar Bear's Avatar
Where are the readings be taken? Can you pinpoint the hex metal area on each spark plug for comparison?
Old May 31, 2024 | 10:22 PM
OLDSter Ralph's Avatar
Engine is in and running. Ran into some defective lifters that needed replacing. A couple leaks that were addressed.
From what I saw from the video, the temperature readings are taken ON the outside of the EXHAUST MANIFOLD. You really need an EGT (Exhaust Gas Temperature) SENSOR to be accurate. I am sure that Cutlassefi has sensors on each header tube for a reason.
Its pretty well established that the center cylinders run a little hotter. You also need to consider the center section of the exhaust manifold is getting exhaust gases from TWO cylinders.
......Just my two cents worth.
Old Jun 2, 2024 | 03:47 PM
arruv89's Avatar
So the engine builder failed to let me know that the I have a 4-7 swap cam. Rewired the plugs and it's running like a champ now.
Old Jun 2, 2024 | 04:22 PM
  #31
I don't understand why people use those things.
Old Jun 3, 2024 | 04:06 AM
  #32
fleming442's Avatar
My best guess would be "m0rE p0wErer!!!"
Seriously, you can gain just as much with proper parts selection, proper machining, and balancing. It will never match newer technology (LS), pound for pound and cubic inch for inch, but definitely respectable on the street.
Old Jun 4, 2024 | 01:33 PM
  #33
CANADIANOLDS's Avatar
I would be more concerned about the 140 psi . That’s not good. unless you specifically asked for it.
Old Jun 4, 2024 | 03:16 PM
  #34
Maybe he wants it to run on regular.
Old Jun 5, 2024 | 02:52 AM
  #35
you can be a lot higher than that and still run regular.
Old Jun 5, 2024 | 08:29 AM
  #36
Sorry, joking. Gotta learn to use these:
Old Jun 9, 2024 | 09:32 PM
  #37
arruv89's Avatar
Car is running like a beast. This thing has been really fun. Got all the outside lights working. Dash lights work. Tach works. Gas says E but is connected. Not sure what the issue is. Speedometer isn't working. Temp gauge is working.
Also after 4years I just realized after installing that the guy gave me 2 1970 bumpers. So have that on until I find a correct one.
Old Jun 10, 2024 | 08:40 AM
  #38
BackInTheGame's Avatar
Sweet!
Old Jul 21, 2024 | 11:58 PM
  #39
arruv89's Avatar
Finally got the correct front bumper shout out to Dave. Got some 15x7 ssii that I'm gonna finish up and throw on soon too. She's been a whole lotta fun driving this summer.
Old Nov 1, 2024 | 10:13 AM
  #40
arruv89's Avatar
Took her to the track for our 1st time
Went up to Sonoma Raceway for the 1st time for Wednesday night drag races. It was an overall super cool experience for my first time drag racing and getting a baseline of where 442 is at. Only was able to get one pass in because I got there late. My reaction time could have been better but not the worst run. Went up with my buddies who had a swooped 455 in 65 cutlass and super stock 4dr 64 f-85. Check out the YouTube link for all the passes. That 65 is running mid 10s. Question i have is what can I do to improve my time? Would like to keep it as stock as possible but open to any and all ideas.
on the ticket I'm the Left side. I raced a 75 vette.
Queenzflip
Jul 3, 2019 04:56 PM
jensenracing77
Jan 12, 2016 02:02 PM
snowman
Mar 9, 2011 08:49 PM
68Tom
May 7, 2008 04:05 PM
malibuskier
Dec 26, 2006 08:09 AM
