68/69 model 455-out of what car?
Old Feb 27, 2011 | 07:27 AM
Harmon's Avatar
I inherited a 455 engine from a friend who got it from another guy that told him it was a 68/69 Olds 455 out of a Hurst Olds.
Is there any way to determine this?
Old Feb 27, 2011 | 07:35 AM
442Harv's Avatar
What heads are on it? If Ds then probably was. Could be C if it was AC car
Old Feb 27, 2011 | 07:36 AM
Harmon's Avatar
They are C heads
Old Feb 27, 2011 | 07:44 AM
All 69 H/O's w/ or w/o AC have D heads
Old Feb 27, 2011 | 07:47 AM
Harmon's Avatar
He told me the heads are off a 400 Olds....did c heads come on that?
There is no way to tell from the block?
Old Feb 27, 2011 | 08:08 AM
Yes,
C heads came on 69 442 w/ 400 cubic inch motor. The D heads came on the 442 400 cubic inch W-30 cars and the 69 H/O with 455 cubic inch motor.
Old Feb 27, 2011 | 08:11 AM
Cameo White's Avatar
Smile
C heads did come on the 68 H/O with AC. I think they were on the big cars in 68 and 69 as well.
Old Feb 27, 2011 | 09:02 AM
allyolds68's Avatar
I would imagine if you had the numbers off the vin pad on the block someone could check them against the 68 or 69 H/O registry. I'm thinking it would be a long shot though. You might make someone pretty happy if you had their matching numbers engine though
Old Feb 27, 2011 | 09:26 AM
Harmon's Avatar
So I need the number on the block which is several numbers and then check it with a registry of hurst olds cars vim numbers? Is it possible to look up the hurst olds registry numbers?
Old Feb 27, 2011 | 09:52 AM
hurst68olds's Avatar
Post the partial VIN number stamped below the driver's side head, behind where the power steering pump would mount.
38M614186 = 3-Olds 8-1968 M-Lansing 6-Toronado 14,186-unit# (late Feb. '68 production)
Old Feb 27, 2011 | 12:16 PM
Harmon's Avatar
38M144104 is the number
Old Feb 27, 2011 | 12:34 PM
38M144104
3-Oldsmobile 8-1968 M-Lansing 1-passenger car (non-Toronado) 44104-unit#
Too early for a '68 H/O.
Old Mar 9, 2011 | 01:31 PM
blueRAYwhale's Avatar
Smile ...maybe
look for a series of numbers(about 3/8" high), stamped on the oil fill tube, towards the top. the first #(i think there is eight altogether), indicates engine build year. it should read 8 or 9 XXXX and so on. may or may not help you if the tubes been replaced. sometimes you have to clean-off the tube and the #'s may be facing towards the intake mainifold.
a1970442
Jan 30, 2015 09:26 AM
Gitso
Jan 5, 2015 05:14 AM
vertex
Mar 21, 2013 02:09 PM
nj_cutlass72
Mar 4, 2012 08:53 AM
kylem4711
Jun 19, 2007 03:06 PM
