'67 Toro engine swap
Old Feb 15, 2017 | 02:55 PM
Brooksie's Avatar
I don't know any local experts on this.
I want to have the engines on my Toros swapped.
Can the motor and transmission be swapped as a unit, or is it less labor intensive to move just the engines?
Asking because I've heard that reattaching the tranny can be quite the chore.
Old Feb 15, 2017 | 03:01 PM
2blu442's Avatar
I've removed them as an assembly and feel that's the easiest way to do it.
John
Old Feb 16, 2017 | 06:35 AM
Given the multiple interfaces between the transaxle and the motor (including the differential bracket and the axle shaft under the oil pan), I agree with John. It's easier to work all those parts with the assembly out of the car.
Old Feb 16, 2017 | 04:18 PM
Brooksie's Avatar
Thank you for your thoughts.
Can you give me a link to anything helpful regarding this?
Old Feb 16, 2017 | 04:26 PM
Spend the money and buy an original 1967 Chassis Service Manual. There are always several on ebay. Do not waste your money on digital versions or repros, as these were all made by scanning an original and detail gets lost.
Old Feb 17, 2017 | 05:26 PM
Brooksie's Avatar
I have a chassis service manual I got on line about 20 years ago. Probably a reproduction as it is two books with plastic comb bindings.
Believe it or not
I refer to it before asking silly questions here.
I will check again but don't recall anything about pulling the motor and tranny as a unit.
Any pointers on what to do or avoid doing would be appreciated.
Old Feb 17, 2017 | 06:46 PM
Not "probably", definitely. Does it even have the Toro addendum at the back?
Old Feb 18, 2017 | 12:17 PM
Brooksie's Avatar
Yes, the second half of book two is exclusive To Tornados.
BeenThere
Feb 1, 2019 02:21 PM
Paxtonshelby
Dec 29, 2015 04:58 PM
vistacruiser1971
Dec 27, 2012 07:35 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
