67 E block 400
Old May 26, 2013 | 07:44 AM
s i 442's Avatar
Oldsmobile enthusiast
67 E block 400
Whats good or bad about them?
This is what is in my 68 442.
Old May 26, 2013 | 08:00 AM
65B01Delta's Avatar
Nothing is bad about a 66 or 67 E Block 400..
Old May 26, 2013 | 08:05 AM
Good: Forged crank, short stroke, proven performer, a far better choice than the G-block long-stroke 400 that was originally installed in a 68 442
Bad: Not the original motor, down at least 55 cu in from where you could be
Old May 26, 2013 | 03:48 PM
s i 442's Avatar
I got a new HEI distributor and 8MM wires coming so I can adjust the timing better, valves are a rattling! Plus I have to install my Performer intake.
Old May 26, 2013 | 05:12 PM
cutlassefi's Avatar
Originally Posted by s i 442
I got a new HEI distributor and 8MM wires coming so I can adjust the timing better, valves are a rattling.
It's not the valves that are rattling. That's detonation.
Old May 26, 2013 | 07:39 PM
s i 442's Avatar
I know that but more people understand "valves rattling" than detonation.
Back in the day when this all started the gas companies said it wasn't low octane gas causing problems it was the " valves making the noise" !
Old May 27, 2013 | 10:57 AM
Been building these cars for four decades now, this is the first time I've heard the term "valves rattling" to mean detonation...
I'm also struggling with how changing to HEI allows you to adjust the timing better. Both the points and electronic distributors adjust exactly the same way - loosen the hold down bolt and rotate the distributor while looking at the timing light. Vac advance and mechanical advance adjustments are also the same in both.
Now, HEI is a GM term that refers to the coil-in-cap distributor. If you mean you are changing to an aftermarket electronic distributor with some sort of computerized advance curve that can be adjusted with a potentiometer, that's different, but it's also not "HEI".
Old May 27, 2013 | 11:26 AM
s i 442's Avatar
Been building these cars for four decades now, this is the first time I've heard the term "valves rattling" to mean detonation... Must be your area because I remember seeing it on TV as a selling point for a brand of gas.
I'm also struggling with how changing to HEI allows you to adjust the timing better. Both the points and electronic distributors adjust exactly the same way - loosen the hold down bolt and rotate the distributor while looking at the timing light. Vac advance and mechanical advance adjustments are also the same in both. I have been adjusting timing since 1982 and on Oldsmobiles.
I already have an HEI in it and its old. Im getting one with a better curve, adjustable pod, better coil and module.
Old May 27, 2013 | 11:31 AM
coppercutlass's Avatar
Chevy budget Olds powered
The reason they said valves rattling to the best of my knowledge is becasue of the valves suppousdley banging on the valve seat due to no lead depostis to soften the blow of them closing but many have said that the have not heard this many have said yes. but detonation will sound sometimes like rocks in a coffee can .
Old May 27, 2013 | 12:31 PM
s i 442's Avatar
Yea, my problem is detonation.
The curve came in around 2000rpms and rattled so I put in a heavy and light spring and it moved up exactly 500 RPMs. So with my new dist I can adjust the advance with a turn of a allen wrench and make it very easy.
I might have to drop my timing a little also and give and take until it stops.
The car is just a show car/ cruise in/ Parts getter, not a race car at all.
Old May 27, 2013 | 01:13 PM
cutlassefi's Avatar
Originally Posted by coppercutlass
The reason they said valves rattling to the best of my knowledge is becasue of the valves suppousdley banging on the valve seat due to no lead depostis to soften the blow of them closing..
If anybody can hear that with the naked ear then they must be superman. More old wives tales. It's detonation, plain and simple.
Old May 27, 2013 | 01:32 PM
s i 442's Avatar
No one said it wasn't detonation, but back in the day they called it "valve rattle" because it sounded like metal to metal knocking.
Anyway back to the original question of good and bad of a 67 400.
Since it has the .921 lifters do they still run the same cam as the smaller diameter lifter?
Old May 27, 2013 | 02:19 PM
Agreed mark i was more or less just explaining how the " valves rattling" is one of those old wives tales and how it kind of came about.
TicTocTach
Jun 16, 2015 04:03 PM
stonecad
Feb 11, 2014 02:02 PM
chrisneu68olds
Dec 30, 2011 10:17 AM
sbFALL63
May 28, 2010 05:45 AM
