67 425 motor rebuild
Old Dec 30, 2024 | 01:12 PM
Dave Wilcoxon's Avatar
Captain Dave
I am looking for a rebuild kit for a 425 ci motor.
I want to do it from the ground up, (if it needs bored out, piston, rods, you name it)
any suggestions?
Old Dec 30, 2024 | 04:35 PM
cutlassefi's Avatar
Oooph, uhh others will chime but not sure you want to go in that direction. Just sayin.
Old Dec 30, 2024 | 05:38 PM
Captain Dave
Ok, well, I asked.
all answers are appreciated.
Old Dec 30, 2024 | 05:40 PM
Captain Dave
I know the 425 parts are hard to find, any advice you can give me would be helpful.
Old Dec 30, 2024 | 05:59 PM
cutlassefi's Avatar
Mahle makes a first quality .030 over piston for the 425, and Molnar makes an H beam rod. Lighter but stronger than the stock stuff.
Old Dec 30, 2024 | 06:05 PM
v8al's Avatar
Registered Olds Owner
Parts aren't that hard to find. The only real 425 specific parts are the crank, rods and pistons. (and possibly the block/cam) The rest is standard big block Olds - 455.
You need to figure out which 425 block you have. Is it a 39 or 45 degree lifter bank angle? Is it a .842 or .921 diameter lifter bore? If the block is 45 degrees then your looking at a non-standard cam grind. If the lifters are 0.921" then you'll have a harder time finding a quality lifter in either hydraulic or hydraulic roller.
For the 425 I found that good piston selection is limited to .030 over. (Mahle Pistons 197816355) You can go .060 but hard to find a real nice piston unless it's custom.
There are some places that will sell you a rebuild kit, but the reality is your better off sourcing your parts individually from places like Summit, Jegs and specific quality Oldsmobile vendors.
Old Dec 30, 2024 | 06:11 PM
Bubba68CS's Avatar
I built one with Mark's help sourcing some of the parts. Mahle pistons, Rocket Racing rods, internally balanced, Edelbrock heads, roller cam, Performer intake, Sniper EFI...
Its what I wanted at the time, and don't get me wrong, its a good engine for what it is. But if I had to do it over again, I wouldn't. Its a hell of a lot of money and it doesn't make the power a more common 455 would, much less a stroker kit in a 455. Unless you're really looking to keep the car original, I'd go for a bigger big block. It'll cost the same and make more power everywhere. Even if you don't want more power, it'll have better street manners for the same cam. There's nothing a 425 can do that a 455 (or bigger) won't do better.
Old Dec 30, 2024 | 06:51 PM
Sugar Bear's Avatar
What is the reason for the rebuild/what are your goals? Is it a high compression motor?
Selecting individual components suggested by our CO member engine builders will result in a more powerful and drivable engine vs. a kit.
Old Dec 31, 2024 | 05:49 AM
Captain Dave
I'm doing a complete rebuild on the 442, I bought a Roadster Shop frame and suspension, I really like the 425, my wife and I are going to drive the car across country as a road trip car.
Old Dec 31, 2024 | 05:54 AM
Captain Dave
I bought the car in 1979,the gentleman pulled the 455 and put the 425 in it to drag race. I did a partial rebuild in 1985, then put it in storage for the last 20 years.
I wanted to restore it before I got too old.
Old Dec 31, 2024 | 06:33 AM
Run to Rund's Avatar
I suggest talking with an expert like cutlassefi (Mark) or Rocket Racing (John Stolpa) about your options and the results you can achieve.
Old Dec 31, 2024 | 07:34 AM
Bubba68CS's Avatar
That's a hell of a lot of money to invest in mediocre performance. Your car though. Talk to Mark (cutlassefi). He can set you up with rods, pistons, cam...hell he can build the engine for you if you're close or willing to ship to him.
Old Dec 31, 2024 | 07:40 AM
67OAI's Avatar
Old(s)GuysRule
You have been around this site for a while so what I can offer you probably have already seen but here goes! If truly a 1967 motor, it will have the more common 39 degree lifter bank angle. If it is a Toronado engine block, it will have the 0.921" diameter lifters versus the more common 0.842" diameter lifter. These are/were great motors and you have the option of keeping the 425 crankshaft and/or since you will be changing pistons and rods you could put a 455 crankshaft, pistons, and rods in it; maybe even a stroker kit. As mentioned in previous posts, contact Mark, cutlassefi on this site, or one of the other Olds gurus such as BTR or Rocket Racing for your build. Good luck and keep us posted!
Old Dec 31, 2024 | 07:51 AM
Captain Dave
I will keep you all informed as I buy parts and get the motor done,
I fell in love with this car the first time I saw it. Hence the reason I still own it after 45 years.
(the color on the car is Bamboo Cream)
Oldsshagginwagon
Dec 16, 2022 10:50 AM
37OldsCoupe
Dec 27, 2020 04:51 PM
imcgm
Dec 27, 2020 01:53 PM
bisscrac
Jun 6, 2012 10:34 AM
delta
Jun 30, 2008 01:41 PM
