66 i think
Old Sep 20, 2011 | 03:51 PM
antbanks78's Avatar
66 i think
Hey
Its been some time since I have been on here but I'm the guy building a 455 for a 78 regal. I am waiting on the heads to be touched up after the 8 months it took me to port them.
Well I found a 66 (i think) toro at a salvage yard, there are lots of nice parts on there, I pulled the motor (by myself in the dirt!!!) and was wondering where I can find an id chart to c what the motor is. B heads and forged crank, 400 or 425?? just pulled cuz I could not bare to c it crushed, and also wanted to let anyone interested know incase they are looking for parts
Old Sep 20, 2011 | 04:20 PM
citcapp's Avatar
Its a 425, sounds like a great find.
Old Sep 21, 2011 | 08:42 AM
antbanks78's Avatar
I took the heads off last night and found 1 cylinder a lil rusty but may be so lite a hone will take care of it. It has the 1 piece rocker arm retainer, big valves, good D and E manifolds but I think it is a 39 degree with large diameter lifters.
Old Sep 21, 2011 | 09:42 AM
Oldsmaniac's Avatar
The toro had a 425 in 66 and 66 and it would be a D block. B heads mean 66 vintage with large valves, larger lifters and a 39 degree cam angle not the 45 degree that regular non toro engines had.
Old Sep 22, 2011 | 07:01 AM
antbanks78's Avatar
Has anyone thought of using the stock roller lifters and retainers from a late model 307 in these blocks? I know you would have to have a cam ground for it, would a cam guy not be able to grind a 39 just as easy as a 45? The retainer plate from the 307 bolts exactly in place of the big block cam oil shield....I'm retro fitting stock chevy roller lifters in my 455 is how I know but if you could use the olds rollers it would be easier...something to think about
Old Sep 22, 2011 | 03:08 PM
sethj78's Avatar
Sorry fellas antbanks78 is actually me, I just haven't logged on in a while and forgot Log in id
Old Sep 22, 2011 | 03:23 PM
Oldsmaniac's Avatar
Just to clear things up a little,,,, the modern and most common cam angle is 39 deg not 45 so there are plenty of these around. The Toro uses a larger lifter and I think the later model 307 engines even the roller ones use the small lifter... so they will not work in the Toro block at all.
Old Sep 23, 2011 | 07:45 AM
sethj78's Avatar
No the late 307 use .9something inch roller lifters...they are to big to fit in my dads 403 and to big to fit in my 455...i have not put a roller lifter in this block but i have a set and if you like I will take a picture?? I have a set of chevys and olds rollers and there is a big difference, I wish they were the same size so I can use the olds retainers, I have to use the chevy retainers with one side cut out because olds lifters are farther apart than the chevys
Old Sep 23, 2011 | 07:52 AM
Oldsmaniac's Avatar
I did not know that... and never heard of someone using those rollers in a .921 lifter engine. The Toro 425 would have a .921 lifter bore.
Old Sep 23, 2011 | 08:16 AM
sethj78's Avatar
i just took some pics of the olds rollers in the D block and next to a chevy roller...let me figure out my photobucket thing and I will show you, but only problem is lifter bore is a lil short so still have to make a bushing to extend the bore because the lifter has a notch that goes above the bore and let oil out.
Old Sep 23, 2011 | 08:36 AM
sethj78's Avatar
307 roller lifters and retainer in a D block 66 toro 425 fit quite nicely
last pic is of chevy roller next to 2 olds rollers with retainer...if you keep looking in the photos when you click on the pictures you will see some of the stuff I am doing with my 455, mostly fitting chevy rollers to it
Old Oct 3, 2011 | 02:42 PM
sethj78's Avatar
I noticed that the pushrods were going into the lifters at an angle, is that an indicater of CBA...if so is it 45 or 39??
Droptop
16
Oct 3, 2010 06:26 AM
cutlass tom
Jan 2, 2007 08:03 PM
1BAD68"S"
Nov 9, 2006 04:30 AM
oldsonlywaytogo
Jul 25, 2006 05:40 PM
