65 cutlass with a 67 toro engine?
Old June 19th, 2013, 12:33 PM
65cutlassnorth's Avatar
Hi all,
Anyone here swap a 67 toro engine into a 65 cutlass?
...and might have tips!!!
thank you,
gary
65cutlassnorth is offline
Old June 19th, 2013, 12:53 PM
Originally Posted by 65cutlassnorth
Hi all,
thank you,
gary
Unbolt the 330, swap the 330 motor mounts to the 425, drop the 425 into the car. This is extremely easy. You'll need the A-body BBO exhaust manifolds. The W/Z manifolds are preferred if you can get them - or headers, of course. You'll want to swap the starter nose from your 330 starter onto the 425's high torque starter and use that one. You'll need to swap the oil filter adapter from the 330 to the 425 also. You can keep the Toro oil pan - it fits the A-body chassis just fine.
joe_padavano is online now
Old June 19th, 2013, 12:57 PM
Great Joe!
This is exactly the info i was looking for. What about mounting it to the existing 2spd or swapping in a TH400.....more tips?
Cheers,
Gary
Old June 19th, 2013, 01:12 PM
Great Joe!
Cheers,
Gary
Your call, it works either way. The Junkaway was factory installed behind the 400 in the 65-66 442s. Of course, you'll prefer the 2.48 first gear in the TH400. Swapping the trans requires a different driveshaft and changing the front and intermediate e-brake cables because of the different trans crossmember location. And of course there's the shifter quadrant issue. If you have a console, you can get a kit to convert the stock shifter to a three speed shifter from Shiftworks.
Old June 24th, 2013, 11:37 AM
Hi Joe,
I've brought the toro engine home (pic attached). Still has the mount below the timing cover and proper oil pan & exhaust etc. seems to be stock from this 67 toro.
I'm also picking up a short tail BOP st-400 from a 67 buick (pitch switch) not sure how i will hook up shifter but might try to do it with the stock column shifter initially.
Thank for the help and i might need more after i clean and paint the 425 and go to install it.
I've searched through this site to find others that might have put a 425 in a 65 cutlass but so far nothing.
Gary
Old June 25th, 2013, 02:59 PM
W/Z manifolds?
Hey Joe,......what are these W/Z manifolds anyway???
Old June 25th, 2013, 05:05 PM
The factory manifolds used on the 1969-72 A-body cars with big blocks. Repros are available if you can't find good originals. Note the letter "W" on the LH manifold and the "Z" on the RH manifold.
Old June 25th, 2013, 05:14 PM
Justin
oldstata's Avatar
You lucky dog
oldstata is online now
Old June 27th, 2013, 06:32 PM
Octania's Avatar
Couple of notes:
That is the best Olds motor made, cherish it....
the 0.921" diamter lifters are expensive and even used ones are not junk.
The AC/Alt brackets are for 66-67 Toro ONLY so do not toss them. You can use the 330's brackets and pulleys on the 425, just use the same length water pump that the 330 had before, and proper length belts. Use the 330's PS pump and pulley too.
The Toro intake is very good. Unless you are going to AL, do not mess with it.
You may wish to fit the car with big block [442] front springs and stabilizer bar.
Octania is offline
Old July 1st, 2013, 10:14 PM
64Rocket's Avatar
I have done the swap and have not had any problems with the stock springs in the Cutlass. Unless they are sagging already with the small block .
Gene
64Rocket is offline
Old July 2nd, 2013, 01:12 PM
Originally Posted by Octania
Couple of notes:
Thanks a bunch. I will stick with the stock intake then. But if i plan a trip to AL then i'll get back in touch!!!!
Gary
Old July 2nd, 2013, 01:13 PM
Originally Posted by oldstata
You lucky dog
Hey thanks Olstata, my girlfriend would beg to differ......lol
Gary
Old July 2nd, 2013, 01:15 PM
Gene
And there's the problem Gene, the car does sag a bit. Probably some to do with body mounts and some to do with spring sag. Last time i felt sad about the height of a car was my 67 ss396 chevelle (sold, sadface) when i finally took it to an old guy spring shop and said lets jack it up and i'll show you where i want it to sit....they did a beautiful job.
Cheers,
Gary
Old July 4th, 2013, 10:53 AM
Rear diff?
Hi all,
Thanks to all that have helped me make decisions and acquire parts. Before I begin to put this together i was wondering about the rear end.
65 cutlass (seized 330cid)
425 cid from 67 toro
ST-400 from a 67 buick (short tail)
W/Z manifolds from a 69 cutlass.
Should i use the stock rear or swap in something more beefy?
I'm just building for street!
Gary
Old July 6th, 2013, 12:17 AM
Threejdsolds's Avatar
Finishing the swap of a 67 Toro 425 into a 64 Cutlass . A couple of pics attached. I am using a Turbo 350 and it bolted right in with the stock drive shaft. Not sure of the length of the 400. I swapped in a 3.55 rear end out of a 67 442. Also used an aftermarket aluminum radiator from Summit. W/Z manifolds fit easily. I suggest that if you plan to upgrade the front brakes that you do so before putting the engine - not a lot of room once the engine is installed. Also, as Joe said, make sure- if you get new motor mounts - to get the 330 mounts. The later 455 mounts are different and will not work- learned this the hard way. Had to add a carb spacer so the stock air cleaner would clear the HEI.
Threejdsolds is offline
Old July 6th, 2013, 07:23 AM
Looks great!
oldcutlass is online now
Old July 6th, 2013, 09:53 AM
Octania's Avatar
Good start
Your water pump inlet is on the LH side, indicating a 1964 330 pump.
I thought your car was a '65 Cutlass... so sayeth the title.
As long as you can connect the radiator bottom nipple to the WP inlet nipple, the coolant flow will work. However, the '64 330 WP inlet on the LH side means that the timing marks were on the RH [edit- was "LH"] side for the 1964 only 330 only. If you wish to use the stock 66-67 Toro balancer and its timing mark, then your timing tab will need to be on the LH side like all the other 1965+ Olds V8's.
I am not that familiar with the 1965 Cutlass radiator configuration, but it seems you may wish to procure a water pump of the same length as the one you have, so the pulley alignment is not disturbed, but the inlet is on the RH side. Then use the Toro timing tab and Toro 425 balancer.
The '65 442 and probably the Toro should have the correct type water pump.
Closer inspection while paying some attention shows me that you have corrected this by the time the engine was fully installed. Never mind! Good info for others who come here looking for tips though.
Octania is offline
Old July 7th, 2013, 10:36 PM
64Rocket's Avatar
Octania, I think you meant the timing mark as being on the passenger (RT) side if you use the 330 water pump. Of which you are correct about using the '65 and later water pump, it should be the same length of the 330 water pump. That way the 330/425 pulleys will line up.
ThreeJ, if your good with the set up you have, then the timing mark will be on the passenger (RT) side.
I'm guessing you bought a radiator that has the in and out in the positions you can use.
Other wise the install looks very clean. If you can fab or find a shroud to fit would be a great idea. The other route would be to use an electric fan and shroud.
Gene
Octania, I just read the thread again and "ThreeJ" has the '64 Cutlass and Toro engine.
It is "65Cutlass" has the '65 Cutlass with the Toro engine. he has not answered yet.
Good start
As long as you can connect the radiator bottom nipple to the WP inlet nipple, the coolant flow will work. However, the '64 330 WP inlet on the LH side means that the timing marks were on the LH side for the 1964 only 330 only. If you wish to use the stock 66-67 Toro balancer and its timing mark, then your timing tab will need to be on the LH side like all the other 1965+ Olds V8's.
64Rocket is offline
Old August 8th, 2013, 01:26 PM
Hi Joe,
Just wondering if i need to remove the front mount from the toro engine or will it clear the crossmember on the cutlass?
Gary
Old August 8th, 2013, 01:44 PM
stan 65 cutlass's Avatar
remove the mount
stan 65 cutlass is offline
Old August 8th, 2013, 02:04 PM
Originally Posted by stan 65 cutlass
remove the mount
Thanks for the speedy reply Stan, will do!
Gary
Old August 8th, 2013, 02:23 PM
glad to have helped, do you have a thread started with pictures yet?
Old August 12th, 2013, 08:05 AM
Hi Stan, I have been taking pictures and will start an album soon. Do you have one for your build? If so please send me the link to it.
Gary
Old August 12th, 2013, 09:50 AM
Gary
here you go, had to dig way back for it. must mean its time to get back at it.winter is long over
https://classicoldsmobile.com/forums...r-project.html
Old August 16th, 2013, 07:30 PM
cadillac kevin's Avatar
sweet swap! toro motor looks like it fit right in.
you wouldnt happen to still have that toro air cleaner decal would you (if it lifted off the lid)? mine cracked.
cadillac kevin is offline
Old August 21st, 2013, 11:45 AM
Very nice Stan....and yes get back to it!
I've started an album...."1965 Cutlass F85 post - w425/toro"
Gary
Old August 21st, 2013, 11:46 AM
toro decal
Hi Kevin,
I do have the decal still on the breather....it's blue. I was going to keep it on there but if i change my mind i will let you know.
Gary
Old August 21st, 2013, 12:09 PM
toro decal
Hi Kevin,
Gary
Actually Kevin, i just realized it says Toronado on it and won't be using it.
Here are some pics....
Gary
Old August 21st, 2013, 07:31 PM
65 442 radiator?
I'm trying to figure out what rad I need.
I want the original style look but for a big block so I have a question.
Q: is the rad cradle any different on a 330cid 65 olds as the 65 442?
Thank you in advance for any help.
Gary
Old August 22nd, 2013, 07:01 AM
you can put a four core in there, they came stock with 4 speeds. mine has one. cradle is the same
Old August 22nd, 2013, 08:14 AM
  #31
core support/radiator
Was there any change in core support or even the radiator when they put a big block in a 65 cutlass?
Old September 3rd, 2013, 05:40 AM
  #32
ydennekkram's Avatar
Hi Gary,
Great looking project! I'm wondering what you did with the exhaust manifolds for the Toronado, I'm needing some and live in the Niagara area. PM Sent.
Mark
ydennekkram is offline
Old September 3rd, 2013, 08:35 AM
  #33
Thumbs up
Originally Posted by ydennekkram
Hi Gary,
Mark
Hi Mark,
Originally i was going to post them for sale. But...since you are a member on here and others have helped me with great info........you can have them.
You mentioned in your PM that one of yours was cracked can you tell me which one? If i remember correctly i may have cracked one ear slightly as i was a bit aggressive getting them off....i'm not 100% on that because i am getting older. I can check when i'm back out to my shop on Wednesday this week.
Cheers,
Gary
Old September 3rd, 2013, 07:44 PM
  #34
Hi Mark,
Cheers,
Gary
Wow, Gary that is really great! Here is a photo of the one I need, hope it isn't the same as the one you cracked cause it's the same problem - cracked ear!!
Mark
Old September 4th, 2013, 06:37 AM
  #35
Mark
I will take a look tonight and hopefully i have the one you need in good condition.
Gary
Old September 4th, 2013, 05:17 PM
  #36
Hi Gary,
Mark
Good news.....my mind played a trick on me.
The manifold I cracked was the one on the 330cid originally from the car. I needed to get the oil filter adapter from it.
So the manifold you want is here and all good. Pick it up whenever you like.
Gary
Old September 4th, 2013, 07:56 PM
  #37
Gary
Excellent news, thanks. I will send you a PM to get your details for location etc. Thanks again Gary!
Mark
Old September 5th, 2013, 08:24 PM
  #38
Just the facts...
BILL DEMMER's Avatar
65cutlass north,
i hate to say it, but you're going to have traction issues. ernie('67 cutlass with non-toro 425) certainly does. his butt is just too light, and since a '65 is smaller, iirc, you may want to think about some ballast in the keester of your car. other than that, it's a blast!
plan on upgrading the brakes, suspension, and steering, it's really required to have anything more than something that goes fast, straight only.
bill
BILL DEMMER is offline
Old September 6th, 2013, 04:43 AM
  #39
Originally Posted by BILL DEMMER
65cutlass north,
bill
So now i gotta run moonshine just to balance things out???? I see some jail time coming should have stuck with the 330........ouch!
Gary
Old September 6th, 2013, 06:32 AM
  #40
I can't believe that adding weight is ever a good way to may a car faster/better handling/better performing. Fix traction problems with tires and suspension (and judicious application of the right foot).
Drag cars use ballast because most classes have a minimum weight requirement. You build the car lighter than that then add the weight back where it does the most good. Street cars don't have a minimum weight requirement, so making the car lighter is the same as adding HP.
Quick Reply: 65 cutlass with a 67 toro engine?
