65 425 Oil sender unit NPT size
Old June 14th, 2016, 08:10 PM
AtomicMyke's Avatar
Hey All, I'm going to plumb a mechanical oil gauge into my engine, my question is does anyone know the NPT thread size of the sender unit where it goes into the block? Thanks!
AtomicMyke is offline
Old June 15th, 2016, 04:00 AM
My gut says ¼", but I am not completely certain.
MDchanic is offline
Old June 15th, 2016, 06:37 AM
Your gut needs calibration. The oil port on every 1964-1990 Olds V8 block is 1/8 NPT.
joe_padavano is offline
Old June 15th, 2016, 06:38 AM
I've always had trouble visually estimating NPT sizes - the actual diameter of the nipple is about double the nominal size.
MDchanic is offline
Old June 15th, 2016, 06:50 AM
Old June 15th, 2016, 09:51 AM
Octania's Avatar
Huh
real numbers
No wonder JP knows all... he has all the inside info!
I always just called 'em
The little one (1/8)
the big one (1/4)
little finger size (3/8)
finger size (1/2) and
thumb size (3/4)
turns out there is also a 1/16 pipe thread- I have some large qty of plugs for that- and they make straight [not tapered] pipe thread think 1/8" for lamp parts). I have 1000 nuts for that thread if you know anyone that makes lamps out of car parts or whatever. pay the shipping and it's yours.
Octania is offline
Old June 15th, 2016, 10:18 AM
Originally Posted by Octania
Huh
real numbers
If you're really clever, you'll scale that on your printer to full size and tape it up in the garage.
Old June 16th, 2016, 03:31 PM
AtomicMyke's Avatar
Wonderful! Thank you!!
loudmouthaussie
Vista Cruiser & Wagons
May 28th, 2014 03:10 PM
Del70
September 15th, 2012 02:06 AM
805cut
April 23rd, 2012 04:08 PM
aussieoldslover
December 12th, 2005 06:48 AM
Quick Reply: 65 425 Oil sender unit NPT size
