'65 425 Fuel System
Old Oct 5, 2012 | 05:31 PM
bills65olds's Avatar
'65 425 Fuel System
I recently purchased a 1965 Oldsmobile Dynamic 88 with a 425 engine. The car has been sitting for about a year and it was parked with a empty gas tank. I've started the engine by running a hose from the fuel pump directly into a gas can just to see if the car runs but would like to find out what is the easiest way to pump fuel from the tank to the fuel pump without running down the battery.
Old Oct 5, 2012 | 06:05 PM
oldstata's Avatar
Justin
Are you trying to clean the tank ?
Old Oct 5, 2012 | 06:58 PM
The tank is clean I'm just trying to get it to pull the fuel from the tank to the pump since the previous owner ran the car empty
Old Oct 5, 2012 | 07:02 PM
oldstata's Avatar
Justin
It shouldn't take much to get the fuel flowing I don't think it should kill the Batt you could always prim the cab it should run for a moment and should have fuel with in sec's
Old Oct 6, 2012 | 06:07 AM
m371961's Avatar
If you have allready ran the car and have fuel in the carb, you won't have a problem. If you want to make sure the tank or line is clear before adding gas, stick line from tank to pump in a bucket or jug and give a burst of air from a blowgun wrapped in a rag into the fuel fill.
Old Oct 9, 2012 | 04:41 PM
I blew out the fuel line, added 10 gallons of fuel and she started right up!!!. Now the next question is the casting for the air cleaner mounting stud is gone. Do I have any options other than replacing the carburetor?
Old Oct 9, 2012 | 04:44 PM
oldstata's Avatar
Justin
Are there any threads left for the rod to go into ?
Old Oct 9, 2012 | 05:00 PM
There are no threads left- the entire piece is gone. The air filter was held down with a bungee cord
Old Oct 9, 2012 | 05:04 PM
oldstata's Avatar
Justin
I would say if there no hole / threads left proble not But there are all kinds of stuff that you could try before making that choice You could always try and locate just the top peice of the carb as well
Old Oct 16, 2012 | 07:33 PM
I went ahead and replaced the carburetor with a rebuilt unit after finding out the car had been driven only 3,000 miles in 15 years. The old carb was gummed up and with the broken casting it was easier just to replace it. I have the car running good but was wondering how many turns out do the two small air screws need to be to start with?. Right now they are at 2 1/2 turns out
Old Oct 17, 2012 | 05:19 AM
rocketraider's Avatar
Oldsdruid
You need a dwell tach or a vacuum gauge to set your idle mixture. 2-1/2 turns sounds just a little rich.
Use the tach to set base idle speed, then turn the idle mixture screws in alternately and evenly 1/8 turn at a time until idle speed drops by 30-50 rpm. Then turn the screws out 1/8 turn which will be lean best idle.
To further fine tune it, connect vacuum gauge to manifold vacuum and adjust screws for highest vacuum reading at idle.
Reset base idle speed to correct rpm which should be 500-600 rpm in Drive on that engine.
Ddbord
Jul 1, 2011 02:39 AM
lshlsh2
Oct 31, 2008 01:25 PM
komondu
Jul 7, 2008 06:07 PM
Jolly Green
Apr 1, 2008 05:29 AM
starchildace
Mar 13, 2006 02:47 PM
