49-64 Camshaft failures
Old Jan 14, 2018 | 08:39 PM
Charlie Jones's Avatar
Phantom Phixer
Recently I have noticed in a quite a few threads that mentioned cam failures . Lobes were " rounding off " , often soon after a " rebuild " .
Several factors were blamed . Proper ZDDP content in the oil , Poor quality "offshore " parts , lack of proper break-in procedure , etc .
Any of those COULD cause a camshaft failure .
But , there is one thing that WILL cause a camshaft failure . And that is improper orientation of the connecting rods during engine assembly .
In the design of the " early Rockets " the camshaft is supposed to be lubricated by what Olds called a " spit hole " . It was a small hole drilled in the side of the rod . When this hole lined up with the oil hole in the rod journal , oil spurted out of this hole . Right toward the camshaft .
These holes must be oriented with the " spit hole " toward the camshaft . If even one rod is mis-oriented that portion of the cam will not be properly lubricated .
I think that this detail in engine assembly might be missed , even by " experts " and " been building engines all my life " types.
Here's a photo from the Oldsmobile Service manual for a better explanation ;
Old Jan 15, 2018 | 09:24 AM
OLDSter Ralph's Avatar
Charlie, its an important point to keep in mind. Many of us may not be aware of the little things. Thank you for posting.
Old Jan 15, 2018 | 01:00 PM
Aviator's Avatar
Great info. Thank you Charlie.
Old Jan 15, 2018 | 01:32 PM
m371961's Avatar
same for later years.
Old Jan 15, 2018 | 06:59 PM
Phantom Phixer
Yes . until 1972 . When the " spit hole " mysteriously disappeared .
Old Jan 16, 2018 | 04:09 AM
m371961's Avatar
Thanks Charlie,i did not know it stopped. Only knew mine had them. Wonder why?
Old Jan 16, 2018 | 04:56 AM
cutlassefi's Avatar
Which basically means they weren’t needed. There are/were lots of reasons for cam failures, not just the lack of spit holes.
Old Jan 16, 2018 | 11:32 AM
Phantom Phixer
This is only speculation , but , The post '64 engines may have better cam lubrication than the "early Rockets" . Olds may have kept them anyway after the 1965 re-design . Just to be on the safe side . Later eliminating them in a " cost cutting " move .
Old Jan 16, 2018 | 09:06 PM
Ozzie's Avatar
It's a good point about the spit hole. Olds wasn't the only one to use it. I've got an old AMC engine with them also. When changing rod inserts be sure the hole in the insert lines up correctly with the hole in the rod. I once had some that didn't too well requiring a bit of refitting with a proper sized drill.
billmerbach
Mar 27, 2014 01:43 PM
67delmont330
Jul 31, 2012 06:13 PM
Joffroi
Jun 9, 2012 07:06 PM
Lady72nRob71
Vista Cruiser & Wagons
Jun 2, 2011 05:06 AM
delkron97
May 15, 2006 08:12 AM
