463 Build
Old May 22, 2017 | 05:30 PM
cutlassefi's Avatar
463 Build
I was a little surprised this one did what it did. It's a 10.0:1 CA build so I ran it on 91 pump instead of the usual 93.
Old May 22, 2017 | 05:32 PM
RetroRanger's Avatar
72 Olds CS
ok dont leave us hanging
Old May 22, 2017 | 05:41 PM
cutlassefi's Avatar
Sorry, not sure why it didn't load the first time.
My Procomp heads with 2.125/1.68 valves
Edelbrock Performer (center divider cut 3/4") No other port match
Custom Lunati Hyd Roller 235/242@.050, .579/.565 lift, 110lsa
RaceTec pistons with 1.5, 1.5, 3.00 ring pack
Federal Mogul mains
Clevite rod brgs
Durabond Cam brgs
Canton 7qt pan
Melling HV pump with purple spring
VR-1 20W-50
QF SS850 (1 jet change)
Pertronix Billet Dist
Accel 9000 wires
Accel 414S plugs
Hooker 1 7/8" Headers
As you can see I run them at what will normally be operating temp. Most don't. Oil didn't even get that hot, that means it's not struggling to make power. That's obviously a good thing!!
Old May 23, 2017 | 09:59 AM
TripDeuces's Avatar
Nice torque down low, nice build.
Old May 23, 2017 | 10:57 AM
cutlassefi's Avatar
Yeah it did pretty well, thanks George.
Old May 23, 2017 | 12:34 PM
Nice, x2 on the torque.
Old May 23, 2017 | 01:39 PM
ELY442's Avatar
Federal Mogul mains
Clevite rod brgs
Durabond Cam brgs
Canton 7qt pan
VR-1 20W-50
Accel 9000 wires
Accel 414S plugs
What will happen if you didnt cut the center divider 3/4? Can you cut it bigger?
Old May 23, 2017 | 03:13 PM
cutlassefi's Avatar
It takes a little out of peak power. I'd only cut it down further if I was using a smaller carb and/or going to spin it up higher.
70cutty
Mar 25, 2019 01:50 PM
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
69 442 protour
Dec 9, 2006 09:25 PM
rodknocker
Apr 17, 2006 08:25 PM
