460 rear main seal in 455, has it been trouble free?
Going through and doing all the gaskets and seal and have read alot of posts different place on guys saying they use the 460 rear main seal in the 455, I was just curious if anyone that has done it has any feed back on it, how long it's been in? Any leaks? Guess I'd like to know if it holds up? I'd hate to put it in and have a leak and have to pull it back apart
Near the bottom:
Valve Cover Gaskets -- VS13403R -- 3/32" thick rubber
Valve Cover Gaskets -- VS50359R -- 11/64" thick rubber
Oil Pan Gasket Set -- OS30471C -- Diesel Engine Type, Metal Impregnated Rubber
Oil Filter Base Gasket -- 9948
Intake Manifold Gasket Set -- MS96009 -- Turkey Tray, Small Block
Intake Manifold Gasket Set -- MS96004 -- Turkey Tray, Big Block
Intake Manifold Gasket Set -- MS96027 -- Turkey Tray, Universal
NOTE: Turkey Tray Gaskets protect the HOT bottom of the manifold from splashed oil, the other kind don't.
Conversion Set -- CS81712 -- Timing Set + Oil Pan Set + Oil Filter Pedestal
Distributor O-ring -- 424
Exhaust Gaskets -- MS90021 -- Standard Type
Exhaust Gaskets -- 1439 -- "Racing" Type, 3 Times More Expensive, not sure why
NOTE: exhaust gaskets are not absolutely necessary if manifolds are straight
Timing Gasket Set -- TCS 13417 -- Gaskets and Oil Pan Seal - No Sleeve
Timing Gasket Set -- TCS45270 -- Includes Speedy-Sleeve for Repairing Balancer Groove
Rear Main Seal -- BS6141 -- Small Block Neoprene Ford Type (Y-Block 239, 256, 272, 292)
Rear Main Seal -- BS13879 -- Small Block Neoprene AMC / Jeep Type (196, 199, 232, 258)
Rear Main Seal -- QBS40032 -- Big Block Neoprene Ford Type (460)
PCV Valve Grommet (Valve Cover) -- 42314 -- Dorman HELP! Number
All I did was loosen main caps 1-4 and removed #5, lifted the crank, got the rope seal out with a pick, used a scotch brute pad on crank, put seal in block and cap, coating of grease on them, dab of ultra black where they meet and put it back together
So I guess that means "No".
Why ask for help when you ignore the advice given?
Bill Trovato (BTR) is the leading Olds engine builder anywhere.
His advice is top notch, and is what I follow.
Hopefully you won't have to redo the seal again.
EDIT: Found it in Video 3. Thank you again for the reference!
The Ford seal is .002” thicker on the outer surface because the OD of the block cavity is .004” larger dia
Wanna bet there’s more variation than that from seal to seal?
the shaft dia difference is .006” bigger for the olds. So .003” per side
theoretically that’ll give .005” more crush per side installed as is.
I've always used the black Felpro seal. Do you have a part number for the blue seal?
I have never had a problem with the Ford seal in an Olds. I just install it with the parting surface slightly offset from the main cap parting surface. The one in my "E" block currently has been in there since 1988.
To change the rear main seal, if i have never replaced my main bearings, is there a worry about loosening the caps and having them not seat properly upon reinstallation and re-torquing.
Also, is there anything worth inspecting since i will be changing the seal. I have read about people using a plastigauge to check bearing clearances. Is it worth doing with old bearing to see what kind of shape they are in?
Cheers
Tony
Cheers
Tony
It wouldn’t hurt to pull a couple bearing caps just to see how things look. At the same time, if you don’t like what you see it will always be in the back of your mind.
Clean out the oil pump pickup, hopefully it’s not full of nylon.
If the timing chain hasn’t been changed, this is the perfect opportunity. Installing the timing cover with the pan on is a pain, since the pan is off that makes it much easier.
