455 won't crank
455 won't crank
After weeks of issues with converting from points to hei I finally got my 455 running smooth again. She has been running great for the last week or so. The other day she all of sudden quiet on me sitting in the driveway and I had to put my charger on it and she fired right up. At the time I really didn't think much of it until now. Got up this morning and she will not crank. It just turns over and over but will not run. I was thinking the battery has a dead cell but I am really not sure. I tried to crank it with some starter fluid as well and no luck. My question is if the battery is to weak to turn the starter will I have fire at the plug wires. I hooked a old plug up the day it suddenly quiet on me in the drive way and I had no spark but as soon as I plug the jumper up it fired right up. Help me understand the relationship in the starter and battery and hei. The starter is turning over but engine will not run. I am not sure if the battery is too weak, but on the other hand I have a full size charger hooked up while trying to get it to run. HeLP
Either it wouldn't crank or it turned over and over.
There can be only one.
Once you can tell us this, we can begin to understand what's wrong.
Why?
So it was turning over?
But IS the battery too weak to turn the motor over? We're still not clear on that one.
And I was taught to say "Please."
We need clarity on this.
If the starter is turning the engine, then obviously the battery is not too weak.
If the starter is not turning the engine around, or is turning it very slowly, then your battery may be discharged (among a host of other possible problems).
By the way, my vote is for a bad HEI module.
...I hooked a old plug up the day it suddenly quiet on me in the drive way and I had no spark but as soon as I plug the jumper up it fired right up. Help me understand the relationship in the starter and battery and hei. The starter is turning over but engine will not run. I am not sure if the battery is too weak, but on the other hand I have a full size charger hooked up while trying to get it to run. HeLP
Bernhard
Jan 6, 2013 09:27 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
