455 w/4brrl but has no power!!!!
Old Jul 14, 2010 | 10:11 AM
  #41
Prsabordo's Avatar
Update, i got the secondaries to open up now and its freaking awesome. When my dad drove it he was so surprised and happy, he loved that deep rore of the secondaries. However i think she is not getting enough fuel once they open up. Since the carb was off a 350 chevy, i am going to upgrade the primary and secondary metering rods and jets. Also sometimes the tranny has a little trouble shifting to the next gear when in drive. Question, does the tranny thats in the 70 delta have any vacuum lines that control the shifting?
Old Jul 14, 2010 | 10:28 AM
  #42
TripDeuces's Avatar
Fantastic, so what was hanging them up? The vacuum modulator on the passenger side just above the pan rail controls shifting at WOT. It requires direct manifold vacuum from the intake. Anyone of those ports directly in the manifold runners would be fine. Mine uses an 1/8 steel line from manifold to trans with vacuum line on each end to connect to the fittings, nothing fancy.
Old Jul 14, 2010 | 01:54 PM
  #43
Prsabordo's Avatar
The air valve spring tension was too high, i have it set at 1/2 a turn. What do you mean by the pan rail and WOT?
Old Jul 14, 2010 | 02:11 PM
  #44
TripDeuces's Avatar
I mean the mounting surface on the transmission that the transmission oil pan mounts to. You'll see a canister with a vacuum nipple coming off it. It's held in with a bracket and a bolt. The question is, is it connected to manifold vacuum with hard line and no leaks present?
WOT = Wide Open Throttle
George
Old Jul 14, 2010 | 02:17 PM
  #45
Prsabordo's Avatar
ohh ok, i don't know if its hard line and or if its leaking. Its 104 outside so i kinda want to wait till it gets cooler to start working on the car.
Old Jul 14, 2010 | 02:23 PM
  #46
Prsabordo's Avatar
Originally Posted by BILL DEMMER
standard 455 recipe:
49B pri. rods
70 jets
7037734 p.p.spring <<this sets the primary mixture contour
AU secondary rods
air valve tension is 1/2 turn from the point of the air valves just closing, on a BBO.
don't worry about the hanger at this point-i don't know why everybody insists on fooling with the hanger. these were for fine-tuning the secondary fuel mixture contour on a per carb. basis, as the carbs. required compensation for manufacturing tolerances.
the big thing is you only have part of the 4-bbl package. you still have small valves, probably a limper cam, and iirc, a lower CR.
bill
Thanks Bill, btw where can i find these parts. I can't seem to find AU secondary rods and p.p spring.
Old Jul 14, 2010 | 08:59 PM
  #47
BILL DEMMER's Avatar
Just the facts...
www.carburetion.com
www.cliffshighperformance.com
or
check with your local dealer for the following part numbers:
secondary metering rods(come in a bag of 2, but the price is for each rod)
AU 7033655, acceptable substitutes, CK 7045781, CV (pretty darn close) 7045984
power piston spring 7037734(come in a bag of 10, but most dealers will sell them individually)
dealer list prices:
AU $24.02ea. found on locator
CK not available
CV $25.53ea. found on locator
7037734 $17.91 found on locator
or, make a trip to the boneyard for everything but the p.p. spring
or, someone on the many olds sites may be able to help you out.
last resort, i have AU rods, 7037734 p.p. spring, 49B pri. rods, and 70 jets, all brand new, some NOS, and prices will reflect this.
bill
Old Jul 15, 2010 | 11:07 AM
  #48
Prsabordo's Avatar
Thanks Bill, im kinda on a budget right now so i'll try my luck at the junkyards and craigslist first. I also have a question for you and everyone else. On the second pic i took which is on the first page of this thread, i noticed this rectangular opening in the back of the carb with a hole in it. I looked up in my Doug Roe book and it says it is a HIC. It also shows a cap over it which i am sure i do not have. What is this HIC and is this important for the operation of the carb?
Old Jul 15, 2010 | 06:31 PM
  #49
Prsabordo's Avatar
rochester cast the HIC cavity into all bowls, only the ones that used it were drilled to allow for it. many rebuilding companies routinely plug the drilled passages with lead during the rebuild process. there were also blank covers used during some years, it was kind of hit or miss. if the holes are drilled and no HIC is installed, that would create a vacuum leak to manifold vacuum and an unfiltered air leak into the air horn area.
bill
Bill, where can i find the parts for this HIC setup? I don't have any of it. My dads car does have a/c but we disconnected the pulley bec it doesn't work at the moment. Also will this open HIC affect carb performance? I noticed when tuning the carb, the idle mixture screws on the primaries are like 4-5 turns out. I also noticed as the car sits for a while, like at a stop light or something, she starts to sputter and bog a little when trying to accelerate.
Old Jul 15, 2010 | 08:23 PM
  #50
Just the facts...
if your HIC cavity is drilled to be functional, you would have a major vacuum leak there. try spraying carb. cleaner into the HIC cavity, if your engine speed changes dramatically , then we can discuss what to do. if the engine speed doesn't change, then you have no need to worry about it.
until you have the proper application-specific calibrations done, it will run poorly.
bill
75hurstoldsW-30
Sep 8, 2014 03:18 PM
michael hilsabeck
Oct 2, 2010 02:11 AM
Wyze
Mar 27, 2010 04:25 PM
oldsdroptop
Jun 2, 2009 07:03 PM
