455 Top end clatter
Old Dec 1, 2025 | 12:01 PM
Moldsmobile98's Avatar
455 Top end clatter
I just picked up a '67 Delta 88 with a 1969 455. It has been sitting for 6 years. After sorting out the ignition it fired up and runs pretty smooth. It does have a clatter around #5 cylender. I'm going to pull the valve covers to check it out but want to see if the sound from this video is familiar to those out there with more experience.
Old Dec 1, 2025 | 02:08 PM
Pulling the valve cover is a good start.
Old Dec 1, 2025 | 03:55 PM
Are you running 10W30? If you go to 20W50 it should silence the clatter.
Old Dec 1, 2025 | 04:42 PM
I doubt that
Old Dec 2, 2025 | 01:37 PM
First thing you need to do is remove the oil filter and cut it open. Make sure it’s not full of metallic debris. Then start your exploratory surgery.
Old Dec 2, 2025 | 06:44 PM
69CSHC's Avatar
Man I hope so.
It sounds like an old diesel engine.
In any case Moldsmobile98 most prudent to go for simplest most cost effective possible solution first and work your way up. ( ie you want to tighten a battery cable before running out and buying a new battery...)
Old Dec 3, 2025 | 08:53 AM
Thanks for all the input. I will update on findings.
Old Dec 3, 2025 | 05:20 PM
Jetmek's Avatar
Dry start from sitting could have burned up rocker pivot. Check filter for metal. Could be a spun bearing. Maybe why it was parked
Old Dec 6, 2025 | 05:42 PM
I pulled the valve covers and with the engine running, no oil coming up through cylinder #1 exhaust valve. Collapsed lifter?
Old Dec 9, 2025 | 10:03 AM
android 211's Avatar
Collapsed lifter, bent pushrod, wiped cam lobe, plugged oil passage. Pull the intake and get a proper look at everything.
oldschool85
Sep 17, 2022 04:50 AM
joesw31
Sep 25, 2021 09:36 AM
Bob Kelso
Oct 14, 2016 02:40 PM
kona-jack
Aug 27, 2009 10:28 AM
Pastor Dave
Mar 25, 2005 10:17 PM
