455 swapped into 350 72 supreme, heater??
First post here! So, I've got a 72 cutlass supreme, originally a 350 car. I swapped in a 455 years back. My original heater and all that wouldn't fit with the big block. What has anybody done for a heater/Ac in a swapped car? I don't think that car was ever offered with a big block. It was an original Ac car. Will a big block chevy heater motor bolt on?? Any suggestions would be great. Thanks!
The stock heater set up fits fine w a bbo in a 70-72 supreme. In the. Nobodies the bbo used a notched set of valve covers to provide some extra clearance. I've got a 72 supreme w 455 in it w stock heater set up
Tall valve covers may be a problem tho
Thanks, Im guessing my problem is that I'm using an AC setup with it. I'll track down one with just heater and try it. My dad has a 72 cutlass S with 350 and no Ac, I'll take some measurements on it. Thanks guys!
Same heater box 350 or 455. There shouldn't be any clearance issues with either engine.
I have had a 455 with standard valve covers in a car that came with a 350 and A/C with no issues.
You COULD have bad body mounts causing the problems. That's about all I can think of besides the car being smacked really hard and having a bent frame that would cause the issue you're having.
Like Randy's pic shows it fits but it isn't exactly roomy at the heater box firewall valve cover junction. I used a spark socket w a hex end to tighten the #8 plug as the socket w ratchet doesn't fit! There is probably 1-1.5 inches between the VC and heater box.
In your case, clearly "somebody" preferred to do something different, and you are left to clean up the mess.
You need to get an A/C setup from another car.
And, No, an Chebby unit will not fit.
Welcome to ClassicOlds.
So, the answer to your question is that "anybody" has simply kept the original heat and A/C parts installed.
Also, car was never hit, and i just replaced the stock motor mounts with new ones, since the old ones were pretty worn. That is also probably contributing to the issue.
Thanks everybody, I will get an update posted after I try again!
I think that "details" here are elusive things.
Note "universal" radiator hose, and lack of not only windshield washers, but windshield wipers as well, but presence of fancy chromed air cleaner and master cylinder cover.
It does have washers and wipers, just can't see em in the pic. Master cylinder is shiny because I just replaced the whole thing and the air cleaner was cuz I had it and the original was all bent up. But, as I said earlier, detail was not my strong suit when I put the engine in the car lol, it was power. I'm wanting to move towards clean and unique, and less "race car".
I've never heard of someone converting a Ac box into a no Ac one before. Just swapping it altogether. I rotated the coil up to get a better pic, but thanks for watching out for me!!
If my memory serves me, the heater core lines pass through the firewall in different locations and would require major metal work to make that happen.
Generic A-body stampings. Correct for a Chevelle, correct-enough for an Olds. I used one (A/C) without issue.
72supreme455, the key is the notched covers like Joe said. Things are really tight in there. Strongly recommend removing the hood and passenger fender.
Looks like a fun car, keep it rolling!
