455 resistor resistance
Old Jun 16, 2018 | 09:37 AM
  #41
cjsdad's Avatar
JEEZ! Now we're talking theory vs. potential? The guy just wants to know if his ballast resistor is good or needs to be replaced. With the points open, the MEASURED voltage will be the same at both ends of the resistor because a typical VOM is not sensitive enough to measure the drop created by the meter itself. With the points closed the circuit will be complete and there will be current flowing through the resistor. The MEASURED voltage will be different now on the downstream end of the resistor. No need to pull out degrees and certificates and measure them. Help the OP fix his car!
Goldenhand
Feb 23, 2017 05:28 AM
boese1978
Aug 9, 2016 10:24 AM
mownhoj
Jun 14, 2016 01:22 PM
Mjt316
Nov 21, 2012 07:35 PM
Bugg
Jun 29, 2012 04:54 PM
