455 questions
Old Mar 18, 2013 | 04:35 PM
Danp76's Avatar
455 questions
I just purchased a 455 engine, code 396021F, with E heads. I think it's a 1970 engine?...Is a 1971 engine as good? Are these good heads? I've heard the E's can have different valve sizes? Should I put in larger valves? I'm missing the exhaust manifolds, are the 350 exhaust manifolds the same? I plan on going through the engine, conservatively, what hp numbers can I expect on a mild build?
Old Mar 18, 2013 | 06:54 PM
Charly9g's Avatar
Hi DanP. I have the same questions. Starting the same (1971w/G heads). let's keep in touch. please let me know what you learn and i will recip! Thanks. Bill. wfg4u@aol.com.
Old Mar 18, 2013 | 07:11 PM
70W-32's Avatar
1970 455(E heads) will have a higher factory compression than a 71(G head) motor.
There are big and small valve heads in each casting. For 1970, pull a valve cover and check for a double valve spring, 2.07 heads used doubles, 2.00 heads used single springs.
On Any other head, you have to pull the head and measure the valve, no external clues as to valve size.(except some mid 60's 442 motors)
Yes changing to bigger valves will help flow.
Machining the small valve heads to big valve is a better route, as the machinist can change the crappy factory valve angles to a better, more perfromance orientated angle.
Prepping iron heads can get relatively expensive rather quick if yours need everything(valves, seats, guides, springs, retainers, related machine work, porting), so keep in mind that you can buy a decent set of aluminum heads all set up for about $1000 from BMRE(Bernard Mondello)
Old Mar 19, 2013 | 06:14 PM
442Harv's Avatar
Just a answer to the last post, the compression differenc between 70 and 71, is not the heads. It is the pistons. Also the G and E heads came big and small valves. The main difference between 70,E and 71 G, is the G have harden seats
esisson
Jul 5, 2008 08:12 PM
Olds64
Jan 19, 2008 12:10 AM
Trouble
Jan 9, 2008 02:20 PM
72Cutlass
Oct 26, 2007 05:45 PM
Rusty Bucket
Jul 22, 2007 10:52 AM
