I have 2 pulleys that I think came off a 1970 455. Can I confirm by numbers? (don't see any) visual? I'll post pics in a few.
And are they worth anything? Been tossing stuff right and left. Preparing to move. Going to travel light,
Anyway these 2 missed the last scrap run because I figured they may be of value to someone? Thoughts? One has a small ding.
They should have a two letter and six digit number application codes stamped in them. If they're straight I'm sure someone would want them. If you can find the letter codes I can try to key them out for you.
John
John
Thanks John!
The little pulley has an KM and opposite that a P
The big pulley shows (after cleaning a bunch) 399405-KC Or "O" but I think its a C
My reference shows the KC 3 groove crankshaft pulley is correct for 1968-71 V8 AC application, it may have the number 399405 stamped across from the KC letters.
Then the KM 2 groove water pump pulley is for a 1968-72 V8 Non-AC application, it may have the number 405461 stamped across from the KM letters.
I've got pulleys that have the two letter code but not the six digit number stamped in them. John
