455 OLDS pilot bushing
I'm looking at a good running 455 OLDS with a turbo 400, it's still in the car, which the seller says is a 1976 ninety eight. I'm interested in putting this engine into my 1965 lemans 4 speed car. Are all 455's drilled for pilot bushings or should I check before I buy it? Thanks, Dave
Dave,
Not all of the 455's are drilled for the pilot bearing.However,there were a lot more of them that were drilled in the later years,like that 76 455,so you have a better chance.
Not sure if you can get a good look before you buy it,but if you can get the car on a lift,unbolt the converter from that flaxplate,and push it back into the trans at all,you "might" be able to see in there,but I don't think the converter will go back enough.All of the cranks have the large hole,for the converter hub,but the 4-spd cranks have a second,smaller hole,inside from that.
Wow! Wasn't expecting a response that quick! It sounds as though I better separate the engine and trans before I buy. The guy is asking $450 for the compete turn key engine and turbo 400, says it runs great with no blow by or smoke. I appreciate the help. Thanks, Dave
Like 507Olds said, late 455s have a much better chance of being drilled already. 2Blu is thinking about 455s in general, because in earlier years usually the crank was drilled for a pilot bearing only if the engine was going into a stick car.
I'd guess you have a much better than 50-50 chance with a 1976. On the negative side, the crank probably won't have the big N meaning nodular, so some say they are weaker cast iron. It will of course be low compression with the smaller port J heads.
My lemans has been sitting since 1981 and since I can't locate a decent pontiac engine, I thought this OLDS would be OK. My car has a wide ratio muncie with 3:31 open 12 bolt rear, just going to be a cruiser. Thanks, Dave
If the crank is not drilled, no big deal. I drill the crank to give room for the input shaft and use the adapter pilot bushing. I done several and have no problem.
You main problem, is to make sure the block has the boss for the "Z"bar.
You also know '76 is low compression , with "J" heads. Not a big deal, will make a nice cruiser, much improved for what is in there now. If it has not moved since '81, it will now cruse with style.
Gene
Gene
Hi Gary,
Good find and only $59.95.
Have you used this on a olds 455?
Did you have to modify it?
Link: https://sdparts.com/details/scoggin-...ts-center/sdcb
Thanks,
Tony K.
Thanks,
Tony K.
I saw one installed on a 72 455, but he had to modify it and/or the frame Z bar mount to clear headers. I have seen them used on Chevelles without mods though. Anyone know if the z bar frame mount is the same in all A bodies?
Just looked, Year One has the same z bar frame mount for chevelles and Olds, so should work.
