455 olds
455 olds
Dec 16, 2004 | 06:13 PM
<duffman>
Guest
n/a
are the exhaust ports on a stock big blocks 455 olds the same as a small block, that is that the center ports are close togther?
Dec 16, 2004 | 09:07 PM
jdorour
Feb 2004
Atlanta, GA.
The port configuration is the same. The bolt pattern is the same also. However, the ports are larger on the big block engine.
jdorour
Find More Posts by jdorour
1968 455 Olds 455 performance motor
dp442
04:22 PM
WANTED a std 455 N-crank or 68 455 steel crank
sx455raidercelticfan
05:45 AM
*1973 455 eninge runs awesome & a 1974 olds 455 rebuilder*
SKINNY IL
07:12 AM
455 Roller 72 Cutlass 455
egknz
01:09 PM
Cutlass Supreme SX - is it genuine
04:07 AM
