455 motor mount ?
just a thought.
to tell you the truth i thought on 70 to 72 you had to use the big block mounts on both sides. i learn something new today.
just a thought.
just a thought.
Joe, I thought the #2261 mounts were for the '68 and older big and small block. And the '70 and up used different mounts for the small block and different ones for the big block Again with matching frame mounts.
Please correct me if not so.
Gene
Gene
Interestingly, if you check the factory parts book, after the new interlocking design for the SBO was released in 1970, it is also shown as the replacement for the early mounts (though of course the parts book uses GM numbers, not the Anchor numbers).
