425 exhaust / headers in 1953 88
Old Aug 11, 2009 | 12:20 AM
Threejdsolds's Avatar
In process of assembly of 67 Toro 425 to go in 1953 88 Hardtop.Car will be for street use. Have grafted in a 1975 N---(Omega) front end. Have ordered Omega front motor mounts. Using a Turbo 400 -will I need to fabricate a trans mount? Also, as it appears the Toro exhaust manifolds will not work,would appreciate advice as to what exhaust system to use in the N---/53 frame combination ( stock dual exhaust manifolds ?, Headers ?, Shorty headers ? ) Thanks, John .
Old Aug 11, 2009 | 08:12 AM
citcapp's Avatar
Yes you will have to fabricate a rear trans mount should be easy. I believe your car has a X frame so angle iron or thick flat stock should work fine. I used W/Z cast iron manifolds on my 57 Olds and they worked great. Don't know about headers someone else will have to chime in on that.
Old Aug 11, 2009 | 08:21 AM
Yes, Toro manifolds definitely won't work. You need RWD manifolds from either a 71-76 full size or (preferably) the W/Z manifolds from a 69-72 442. The latter are being repro'd. You will need to fabricate a trans mount because the 53 used mounts on the sides of the bellhousing. Use a universal trans mount crossmember.
Old Aug 13, 2009 | 12:14 AM
Thanks for your help guys ! I really appreciate it . John
Wyze
Mar 18, 2012 01:59 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
DAN76
Jan 8, 2009 10:07 PM
2tuff65
Sep 7, 2008 03:31 PM
psmopar
May 7, 2007 06:55 PM
