455 lifter bores
Old Aug 23, 2008 | 03:05 PM
CutlassSalon's Avatar
455 lifter bores
Can the lifter bores in a 455 be bored to accept roller lifters from a 307? It seems that roller cams aren't much more expensive than a flat cam, it's all the other stuff that goes along with it that costs the money. (roller lifters, cam button,etc) Also will beefed up 5A heads work on a 455? Will they work in conjunction with a roller cam? What kind of compression would they give me?
Old Aug 23, 2008 | 06:16 PM
The stock 307 roller lifters are fairly heavy. More to the point, you should get lifters and cam as a matched set from one vendor. The 307 heads will bolt up to a 455, but why would you want to. Smaller ports, smaller valves, not your best choice.
Old Aug 23, 2008 | 07:16 PM
You're right about the smaller ports and valves. My reasoning behind it is to bring the compression up so I can run E-85. I can put bigger valves in and I want to try my hand at porting. If I tear up the 5A heads there's really no love loss because I still have the E heads that came on the 455. I don't want to raise the compression with just the pistons because there is a rumor that they are doing away with the sale of E-85 in Missouri. So just in case that's true, I want to be able to put a stock set of heads back on it so I can run 89 or 91 octane without changing the pistons too.
What about a set of 4A heads from a 403? Would they be a better choice?
Old Aug 24, 2008 | 07:45 AM
I think the 5-6-7 heads from an early 350 would be a better choice. You can put big block sized valves in them.
Old Aug 24, 2008 | 11:43 AM
dan2286's Avatar
Good idea to go with e 85. I have seen alot of racers using it as cheap race gas. People have said that they are making more power and longer lasting engines.
Old Aug 24, 2008 | 01:29 PM
I'm afraid I have to wonder if the smaller ports will negate any benefits.
Old Aug 24, 2008 | 06:33 PM
Yeah, I like the sound of E-85. It's race gas octane at pump gas price. I know the production of E-85 is raising the price of corn which directly effects my farm and the cost of food, but they are going to make it anyway. So I am jumping on the train.
You're probably right Joe. If I go searching for these 350 heads in a salvage yard, what would be a good price for good cores?
1956OldsDarrin
Jul 8, 2012 09:37 PM
Moose
Jun 14, 2012 08:43 PM
Railguy
Apr 9, 2012 07:29 AM
Troys Toy 70
Feb 3, 2012 07:59 AM
dster69442
Dec 3, 2010 07:50 AM
