455 id
Welcome to C.O. andyman
If your 455 is out of the car, check the engine stamping pad (just below and to the left of the #1 cylinder. The stamping pad faces down but will tell you the plant, year and last 6 numbers of the VIN the car it was built for. Sometimes the stamping pad is pretty dirty so you may have to clean it to read the info. Should start 3(pnt code)(lst digit of yr)(123456 VIN derivative)
clik on Tech on the C.O. Tool bar and navigate through the engine info.
You can also go to the Wild About Cars website. It's not that easy to find stuff there unless you know where to look.
Try these links and see if they work for you
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
Anyways I figured out the big block I am building is a F '70 - '72 455 396021 and than I broke the vin stamping down to a Olds 71 Lansing built and have the last 6 of the vin but still not sure what it is out of.....Delta 88, 442 or something else. Is their a way to go further? Thank you for any help.
Your heads should have a G casting (that's good because they have hardened valve seats in anticipation of unleaded fuel). Head casting number is 409100. If by some stroke of luck the heads have an H cast on them, you have some rare W-30 heads that are worth big $$$$$.
The intake manifold could have any of the following casting numbers
407566 - 2bbl
407570 - Aluminum OAI intake.
407567 - 4bbl
407568 - 4bbl SMT
231315 - Toro engine
If you look by the distributor hole, there will be 2 sets of numbers - a single digit and underneath a 3 digit. That's the casting ordinals. The single upper number is the mold it came from, the second is the casting date.
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
