455 Id
Old Oct 21, 2006 | 07:34 PM
lostboy's Avatar
455 Id
Hello I'm new this forumI have looked around but the same old story I'm trying to find out a little info about my455. The numbers I have found on the Block are 36R178199 and on the Heads it is marked 383821 and it has a large A on them a 2 and cfd . If anyone could help me out or show where to go it would be a great help. Thank You Bak
Old Oct 21, 2006 | 08:03 PM
texasred's Avatar
Tom Servo's Stunt Double
Check the "Oldsmobile Performance" section on the menu bar at the top of the page.
C.J.
Old Oct 21, 2006 | 09:00 PM
lostboy's Avatar
Thank You I'm learning now what did Olds put the 400 425 in in1965
Old Nov 17, 2006 | 02:56 PM
rockethound's Avatar
ok,
3 is old divition
6 is year
r is assembly plant
the last six is vehicle serial number
this is found on the drivers side of the block.
the casting number next to the oil filler tube is the block code.
the 383821 A head is a 1965 400-425 cibic inch head.
hope this helps
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
