455 help
Old Feb 27, 2015 | 07:06 PM
jordan845's Avatar
Smile 455 help
I have a 455 with a performer intake and quadarjet . It has c heads the cam with 472 intake lift and 496 exhaust lift and dur 296 and 308 and headers . How well this run I have in a 68 442 with 3.42 gears and a six speed transmission .
Old Feb 28, 2015 | 07:20 PM
jordan845's Avatar
Will this setup work well on the road and racing ?
Old Feb 28, 2015 | 07:28 PM
wr1970's Avatar
Should run great on the street! Now for track depends on what is inside for bore and stroke,pistons! My guess your car may run in the thirteens! More info is need to access better! What is your goal then work towards that goal. I hope this helps
Old Feb 28, 2015 | 07:37 PM
drjr56's Avatar
My 400G in a 69 442,with a QJ Carb,Performer intake,crane cam 491/518 lift and 226/234@.050 400turbo,373 gears,and 10.5 pistons,went 13.9@100mph. 60ft were only 1.8 didn't beat the car.That was with closed headers,and flowmasters.Car ran fine and was fun to drive on the street.
Old Feb 28, 2015 | 07:51 PM
jordan845's Avatar
Its a 455 4.125 bore x 4.250 stroke 8.5 to 1 cast pistons
Old Feb 28, 2015 | 08:50 PM
wr1970's Avatar
Jordan i think you will be very close to 13 in the high or very low 14! Everything depends on tune, suspension boxed lower control arms, shocks, springs,Slicks! Not to mention motor is not a high performance engine because of the pistons compression ratio. Unless you do these things car will not be very fast but will be fun to drive and still be able to race just fine. Food for thought! There are others on here better to advise than me. Guys like Don 80 rocket. Many others.One thing to remember don't go peeling out with a posi trac rear end and turn corners burning rubber! You will wear out your posi unit quickly! Straight line only! I hope this helps.
Old Feb 28, 2015 | 09:02 PM
jordan845's Avatar
Yes thanks
nolabigdawg
Nov 16, 2014 06:45 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
MJAKS462
Apr 15, 2010 02:34 PM
egknz
Jul 21, 2009 01:09 PM
