455 engine water pump
I am curious if anyone has ever seen this water pump set up before?
It looks like some kind of PTO unit at the back of the engine.the head stamping looks like a K is that possible
Used to run irrigation pumps for long periods of time.
I believe also they were 460cid engines.
Maybe others have better info, but this is my belief.
stetzie
Boat motor. Those exhaust manifolds are water cooled by the pump, it looks to be a closed system, that tank on the back would be the radiator. Opposed to sucking fresh water in from outside the boat. So the water jackets shouldn't be bad at all. Looks to have had a through hull exhaust to. This motor probably lived a high RPM life is some speed boat.
Some boat motors also come with bigger cams then the stock auto engines did because these were designed to run at WOT more then Idle. Mercrusier (chevy) ID the engine's by a horsepower rating opposed to displacement.So a Merc 260 is really just a 350 Small block rated to 260 HP. Most others did also, the plate is normally found on the carb. You may be able to find what the factory rated the HP for that specific motor then somewhere on it.
Nor Cal Andy
March 29th, 2012 07:27 PM
