455 engine id help
Old Dec 15, 2019 | 06:23 AM
tt455's Avatar
455 engine id help
I recently purchased my first Olds a 69 442, so here is what I have, casting # 396021 F. I do not see a 2 letter code on the oil filler tube. On the heads is the letter G and I see 409 100. From what I can gather this may be a 1971 455? I'm not sure what car it came out of, are there any other numbers I can look for to determine this?
Old Dec 15, 2019 | 06:29 AM
tt455's Avatar
I know it has to be cleaned up, another couple shots of engine.
Old Dec 15, 2019 | 06:54 AM
RetroRanger's Avatar
72 Olds CS
Below the G on the drivers side is a pad w a partial vin. That will give you a clue what the engine came out of. It does spear to be a 71 455 assuming the heads and block came together.
Old Dec 15, 2019 | 07:05 AM
lunaboy's Avatar
The Rocket Astronomer
yes as you are aware the heads are 71 G heads, the casting # 396021 for the year 455 it came out of
can be deciphered just by your pic of the casting you provided; with the font or Sherrif syle F after the casting. casting "F "with sheriff or legs on the F is a 1971 casting.
a 70 455 has a plain F and the 72 and up have a Fa following the casting.
you can further verify year by checking the partial vin on the eng stamp pad.
Old Dec 15, 2019 | 07:19 AM
The second character of the VIN derivative stamp is the model year of the engine (well, the block anyway).
Old Dec 15, 2019 | 08:37 AM
tt455's Avatar
Great info, thanks so much I will take a look.
Old Dec 15, 2019 | 09:10 AM
tt455's Avatar
Ok so after sanding off some heavy paint I found these numbers.
Old Dec 15, 2019 | 11:09 AM
hurst68olds's Avatar
31M185336
3 = Oldsmobile
1 = 1971
185336 = 85,336th assigned A-body VIN from Lansing for the '71 Model year (of 132,484 units)
daddybx
Aug 8, 2019 05:32 PM
1partshelp
Mar 27, 2017 01:32 PM
Djcoak
Mar 1, 2013 01:50 AM
coldwar
Aug 22, 2012 05:47 PM
hunter
Oct 11, 2011 12:09 AM
