455 engine id
Old Sep 23, 2010 | 07:34 PM
gbodyfan's Avatar
455 engine id
I bought 2 455 from an old guy who didnt remember what they were out of. I was wondering if there was any way to tell what they were out of. Cast numbers are 396012 F looked that up says from what i can tell 70-72 455. They have steel 2bbl intake num 388625. Both have C heads. But the thing that got me wondering was they both have drivers side center dump exhaust manifolds. 1 has pn 384785 and i cant see the other 1 looked that up they say 67-69 LH full size 425. I quess the question is was there any 455 that used those manifolds thats why i am trying to fig out what they came out of. But i am figurin they were prob switched for some reason.
Old Sep 24, 2010 | 12:32 AM
64Rocket's Avatar
They are 455's. they both came from a '68 full size Olds, maybe '69
Gene
Old Sep 24, 2010 | 04:19 AM
f-85's Avatar
If you look under the head on the driver side, right in front is a little pad. It should say 38m****** or 39m******* the 8=1968 the 9=1969
Maybe the motors where in some kind of racecar of some sort that the rules called for stock type pats. the center dumps flow good.
Old Sep 24, 2010 | 05:52 AM
507OLDS's Avatar
Sounds like 68/69 delta 455's. Nothing wrong with those.
Old Sep 24, 2010 | 09:19 PM
gbodyfan's Avatar
The guy thought they were out of early 70's cars but didnt remember. Hopfully they are out of a 68 or 69 so my odds of finding a nodular crank are better. The center dump manifolds are a only on the drivers side and they have the crossover pipes hooked up. I assume the manfolds were switched but was just wondering if they were supposed to be that way. Also that guy never raced so i dont know why they would be there.
Old Sep 24, 2010 | 09:45 PM
gbodyfan's Avatar
Ok just went to the garage ad checked the motors i could get to and these are the numbers
38x128642
39c107848
38x162750
31m414647
I would assume that the 2nd number indicates the year 68 69 68 71? What do the rest of the numbers mean?
Old Sep 24, 2010 | 10:02 PM
svnt442's Avatar
The letters are the assembly plant at which the car was assembled and the last 6 numbers are the order in which the car was assembled starting with 100001.
Here are the assembly plant codes.
B = Baltimore, MD
C = Southgate, CA
D = Doralville or Atlanta, GA
E = Linden, NJ
G = Framingham, MA
K = Kansas City, KS
L = Van Nuys, CA
M = Lansing, MI
R = Arlington, TX
W = Willow Run, MI
X = Fairfax or Kansas CIty, KS
Z = Fremont, CA
1 = St. Therese, Canada
2 = Oshawa, ON Canada
Old Sep 25, 2010 | 05:07 AM
f-85's Avatar
38x128642
39c107848
38x162750
31m414647
Sounds like you got a bunch of good motors over there!
Old Sep 25, 2010 | 09:24 AM
38x128642 = 1968, Fairfax, KS
39c107848 = 1969, South Gate, CA
38x162750 = 1968, Fairfax, KS
31m414647 = 1971, Lansing, MI
The leading "3" means Oldsmobile division and the last six digits are matched tho those of the VIN from the car the engine came out of.
Old Sep 27, 2010 | 08:21 PM
gbodyfan's Avatar
Does a 396021 Fa mean anything?
Old Sep 28, 2010 | 12:58 AM
svnt442's Avatar
It's a 73-76 block. The slightly modified the casting is all.
Old Sep 28, 2010 | 05:21 PM
gbodyfan's Avatar
Modified better or worse? The number on the Fa block is 33m224626. I seen on 442.com that Fa could be a marine motor said "L vin derivative" i asssume since it has a M its not marine. Are the marine blocks any better? Is there any diff between marine and normal blocks.
Old Sep 28, 2010 | 09:27 PM
svnt442's Avatar
Nope. From what I know the marine blocks are the same.
I think they upgraded the oil drain back in a couple spots on the FA and that's about it, but don't quote me on that.
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
pinky
Oct 1, 2007 11:24 AM
