455 done.
Old Jul 4, 2016 | 08:52 PM
Gre975's Avatar
455 done.
Here's my 455 I recently finished building. It's a 71 block with mildly ported G heads, Erson cam, nodular crank, high volume pump, Kevko 7 qt pan, Edelbrock intake, Scorpion rockers, and forged pistons w/ 10 to 1 compression. I'm putting a 200 4r with a 3000 stall behind it along with the 3.42 gears for now. I am also waiting on my Hooker Competition headers. This is going in my 71 post coupes Cutlass. I'll be taking it to TLC restorations in Milton Wisconsin for some dyno time soon.
Old Jul 5, 2016 | 05:38 AM
Very nice.
Old Jul 5, 2016 | 06:53 AM
RetroRanger's Avatar
72 Olds CS
Looks like it's ready for business....
Old Jul 5, 2016 | 01:06 PM
BackInTheGame's Avatar
A Thing of Absolute Beauty!
Old Jul 5, 2016 | 07:52 PM
Gre975's Avatar
I'll post dyno numbers asap. Taking it on Monday the 11th.
Old Jul 5, 2016 | 08:10 PM
don71's Avatar
same but different
Yea, that is nice and clean. My favorite moment in the car hobby is firing the engine for the first time. Anticipation of dyno day would get me no sleep.
Old Jul 8, 2016 | 03:41 PM
Nitz1973's Avatar
Very Nice. I like the painted edelbrock intake touch.
Old Jul 8, 2016 | 03:46 PM
scrappie's Avatar
Nice looking engine what are the cam specs, carb and distributor ?
Do you have that motor in your bedroom?....LOL
Old Jul 8, 2016 | 09:35 PM
TripDeuces's Avatar
Good for you, looks like a fun ride
Old Jul 9, 2016 | 09:21 PM
Gre975's Avatar
Scrappie, cam is somewhere in the. 504 lift and .236 duration. I don't have the card nearby. Carb is a Holley 750 vacuum secondary. Distributor is a billet hei from Rock auto.
Old Jul 11, 2016 | 08:39 PM
Gre975's Avatar
Well no dyno. Shop said their dyno requires a crank drilled for a pilot bearing. I called another shop to see if they can do it.
Old Jul 11, 2016 | 08:44 PM
coppercutlass's Avatar
Chevy budget Olds powered
I would just get it out on the track buy some sticky tires and have a blast.
Old Jul 13, 2016 | 03:51 PM
Gre975's Avatar
TH400 should be ready next week. I'm having B and C transmission out of Machesney Park Illinois build it for me. I'm gonna forgo the dyno and just put the motor on a test stand this Sunday to check for leaks and overall condition.
Old Jul 13, 2016 | 04:26 PM
Wish I knew you where going that way for a trans. A buddy of mine is an expert with the th400 and builds many a week for racers and derby cars. He is out in rockford.
Old Jul 18, 2016 | 05:45 PM
Gre975's Avatar
Motor has been run on the test stand and got my transmission from B&C!
Old Jul 18, 2016 | 05:54 PM
TripDeuces's Avatar
Looks like one serious converter.
Old Jul 18, 2016 | 07:43 PM
815Cutlass1972's Avatar
" Hoo yah "
Did Pakes build your 455?
Old Jul 18, 2016 | 08:10 PM
Gre975's Avatar
Pakes did the machine work on the motor (block bored/honed, crank polished, head work). I assembled it after getting it back a few weeks ago.
Old Jul 18, 2016 | 08:17 PM
" Hoo yah "
Sweet! I see the dog dish caps still look good. I think you bought my last set.... Car looks good bud.
Old Jul 18, 2016 | 08:29 PM
Gre975's Avatar
Haha yeah I remember that! And I'm pretty sure we bumped into each other at Byron last fall!
Old Jul 21, 2016 | 06:28 PM
Gre975's Avatar
Bought a dipstick and tube for the 400 from Inline tube. Fits great with the bracket lining up with the bellhousing bolt. Quality is good too. Also ordered an aluminum Summit Racing performance fit radiator. I've got my old brass 3 row available if anyone is interested. No leaks just decided to try aluminum for the 455.
Old Jul 21, 2016 | 07:13 PM
If you hit byron anytime soon let me know .
Old Jul 22, 2016 | 06:12 AM
Gre975's Avatar
Will do
Old Jul 27, 2016 | 09:01 PM
Gre975's Avatar
Going in
Old Aug 9, 2016 | 11:50 PM
Gre975's Avatar
Ok so the motor is in, however now I've got a starting issue. Fully charged 1000 cca battery ( tested at 12.78 volts), motor grounded from back of cylinder head to clean, sanded part of frame, and motor won't even crank over. No clicking of solenoid either. Starter is brand new Powermaster mini. Motor started and ran fine on test stand.
When I open the door, the dome light turns on. If I turn the headlights on, the dome light turns off. Oh and the headlights never come on either. I also don't have any dash lights at any time during this.
Horn relay shows same voltage as battery too. Am I missing something? Could my ground be bad since the cylinder head is painted and not bare metal? Any help will be appreciated.
Old Aug 10, 2016 | 04:25 PM
BlackGold's Avatar
You say the engine is grounded from the back of a cylinder head to the frame, but is there a ground connection from battery to engine? The negative battery cable is supposed to bolt to the engine block (though many people bolt it to the front of the cylinder head). THAT's where the starter current wants to flow, not through the ground strap on the back of the engine.
Old Aug 10, 2016 | 06:40 PM
Gre975's Avatar
Yes battery is grounded to engine block too
Old Aug 10, 2016 | 06:41 PM
72 Olds CS
What BG said battery to engine block in front and cylinder hear to firewall in back and definetly clean off the paint too
Old Aug 10, 2016 | 06:44 PM
Olds442redberet's Avatar
That's a pretty motor.
Old Aug 10, 2016 | 06:47 PM
Gre975's Avatar
Well I just tested the battery with the key on. It went from 12.7 v to less than 1 v with the key in the starting position. Bad battery?
Old Aug 10, 2016 | 07:48 PM
  #31
z11375ss's Avatar
Senior Moment Member
Agreed. Make sure you check to see if the fuse block is connected properly to the firewall. I had this problem and this is what fixed it. Check it out.
Old Aug 11, 2016 | 06:42 PM
  #32
Gre975's Avatar
Replaced battery and she fired up just fine. Thanks for the help.
Old Aug 12, 2016 | 08:05 AM
  #33
1BOSS83's Avatar
Video would be awesome. Nice looking set up!
Old Aug 18, 2016 | 02:16 AM
  #34
Gre975's Avatar
Car is up and running and she pulls like a freight train! TONS of torque. Special thanks to cutlassefi on his camshaft recommendation. Great cam for my setup!
Old Aug 18, 2016 | 02:34 AM
  #35
Gre975's Avatar
Hope this video shows up ok
tex70
Dec 18, 2006 12:59 PM
daverbmxer
Dec 16, 2006 07:29 AM
TOONLOVESCHERYL
May 17, 2006 07:52 PM
55rocket
Dec 1, 2004 06:23 AM
