455 cam bearing question
Old May 30, 2020 | 07:27 AM
Kadman's Avatar
I’m currently freshening up a1968 455 to be installed in my 65 Cutlass. Part of this included a cam swap. When I pulled the old cam I took a good look at the cam bearings. The lower half of the bearings look great with no scratches or excessive wear. The top half of the bearings have a black deposit I would best describe as burnt oil. I pulled the engine from a low mile Olds 98 (53000 miles) and the inside looks almost new. I’m on a tight budget and was not planning on replacing the cam bearings. Looking for suggestion from folks that have more experience than I on this issue. Suggestions? Thanks
Old May 30, 2020 | 11:13 AM
Sugar Bear's Avatar
It's probably fine as the load would be mainly on the low/bottom side of the bearing surface. Will it wipe clean with a solvent?
Best would be to measure them and post a picture.
Good luck!!!
Old May 30, 2020 | 11:49 AM
v8al's Avatar
Registered Olds Owner
I observed something similar on the mains of a original 70 350 of unknown mileage that I disassembled.
Acetone wouldn't take off the 50 year old stains.
Original GM 1970 350 bearings after 50 years and unknown mileage.
Old Jun 1, 2020 | 04:08 PM
Kadman's Avatar
Parts cleaner cleaned it off a bit but not totally.
Old Jun 2, 2020 | 04:03 AM
BillK's Avatar
Its just burnt oil varnish. I wouldnt worry about it. Brake clean will probably take it off better than parts solvent.
tru-blue 442
Mar 30, 2022 09:53 AM
Majic Jack
Aug 11, 2015 10:44 AM
1968ragtop
May 10, 2015 09:02 AM
coppercutlass
Jul 11, 2014 05:39 PM
dman0712
May 17, 2010 05:55 PM
